the dash i made.. (pics inside)
stangster50
129
cranston ri
since im doing the 5.0 swap, well, the right way, and the stock tach and stuff wont work anyway, plus aftermarket is more accurate anyway i decided to make my own cluster. i had some sheet aluminum lying around, so i made templates and cut out not only the cluster, but ac vent deletes (has ac delete) an aftermarket sterio bezel/mount, and an ashtray door. (to replace the missing one) i then drilled the guage holes with hole saws, and modified the stock speedo to match the aftermarket guages. i also decided to stick a sn-95 style pony into the center vent. all the pieces were buffed with an abrasive wheel on a dremel for a brushed look, then clearcoated and wet sanded/buffed to make smooth as glass and protect it.
heres the pics.. (sorry for the poor quality, and the fingerprints on the speedo plexi-glass and stuff) what do you all think?
thanks. ive been thinking that. trying to decide if i liked it or not. im trying to keep it kinda clean. thanks for the nice comments so far guys. because i am only 17 ppl dont think i can do this sort of thing.. thats why i would rather take pics then talk about it ya kno?
Maybe some small speakers and custom speaker grills for the vent openings.
--also--
A Pony engraved piece of billet aluminum might look good as a replacement for the Pony emblem.
Otherwise, I like it. That gauge cluster you made looks sharp. Def need a 140 speedo though.
