The mustang has rough idle and won't smooth out
Helltime
9
Des Moines
Me and my dad are working on an 83 mustang GLX 5.0 5speed and we can't get the idle to smooth out. We put a new edlebrock carb, plugs, wires, cap, rotor and coil and tuned the carb and the idle will not smooth out because it still has a miss. Would a small vaccum leak cause this. Any suggestions will be greatly appretiated. Thank You
Is it a ramdom miss or a constant miss ? If it's a constant miss try to isolate which cylinder is missing and what is causing the miss. Take a rag and place it under / around the tailpipe and see if you get a flapping sound as if it's trying to suck the rag back into the tailpipe. That will at least tell you which side the miss is on.
Helltime said:
We think it is cylinder 8 because that doesn't seem to make any difference when the plug wire is clear off. We do have a vaccum leak but at 800rpm it is pulling 21pounds of vaccum even with the leak.
If it's a constant miss on one cylinder and it is getting a good spark it sounds like it's loosing compression in that cylinder. If fixing the vacuum leak doesn't clear up the miss, it might be time for a compression test.
