i don't know how you can go through this again i have a friend that is also on motown muscle with us and he has a 83 capri with t-tops .the thing is a totla rust bucket for the most part but is repairable .i would love to do a capri but after going with what i am going through with this car i can't see doing it again.major props to you to because it is alot of work and i can see why you wouldn't want to go through the trouble of painting the bottom and such.atleast this time when you get it done i would love to see it at the mustang car show in novi. good luck with the build
Thanks man. I told myself and others that I would never do it again. But I can already see this is much easier putting 97 stuff into a 91 than putting 01 stuff in an 81. I don't have to modiy the gas tank neck, because the fox neck is the same diameter as the 97 neck. All the lines bolt directly in place under the car. Ford changed nothing. I don't have to weld brackets to the car like I did on the 81. I don't have the evap canister in the left rear wheel well. I don't have to cut holes in the front fender aprons for the air filter or the washer bottle....or where the ECM harness goes into the car.
I can see that this will be slightly easier. And I know where to cut the dash this time. So this time I can make 2 or 3 cuts rather than 20. lol. I can't wait to get more pics up because that means more work is done!!!
