i've made some calculations using the t3650 gear ratio
1st: 3.38
2nd: 2.00
3rd: 1.32
4th: 1.00
if you shift from 1st gear at 5200rpm, 2nd gear rpm would fall at 3076rpm, same goes for 3rd gear, shifting from 2nd to 3rd at 5200rpm, 3rd would go at 3432rpm, shifting from 3rd to 4th at 5200 rpm would put 4th gear at 3939rpm.
using the previous dyno graph, you guys can select a most optimal shifting point. hope this help
RPM --- 2nd gear rpm ---- 3rd Gear rpm ---- 4th Gear rpm
5200 --- 3076.92 --------- 3432.00 --------- 3939.40
5250 --- 3106.51 --------- 3465.00 --------- 3977.27
5300 --- 3136.09 --------- 3498.00 --------- 4015.15
5350 --- 3165.68 --------- 3531.00 --------- 4053.03
5400 --- 3195.27 --------- 3564.00 --------- 4090.91
5450 --- 3224.85 --------- 3597.00 --------- 4128.79
5500 --- 3254.44 --------- 3630.00 --------- 4166.67
5550 --- 3284.02 --------- 3663.00 --------- 4204.55
5600 --- 3313.61 --------- 3696.00 --------- 4242.43
5650 --- 3343.20 --------- 3729.00 --------- 4280.30
5700 --- 3372.78 --------- 3762.00 --------- 4318.18
5750 --- 3402.37 --------- 3795.00 --------- 4356.06
5800 --- 3431.95 --------- 3828.00 --------- 4393.94
5850 --- 3461.54 --------- 3861.00 --------- 4431.82
5900 --- 3491.12 --------- 3894.00 --------- 4469.70
5950 --- 3520.71 --------- 3927.00 --------- 4507.58
6000 --- 3550.30 --------- 3960.00 --------- 4545.46
