the steering columns
hsean
656
69
69
dearborn,michigan
is there a difference in lengh between the 87-89 and 90-93 columns besides the tilt steering obviously ?i sm thinking of putting an airbag steering wheel on my tilt column will this fit ?is there going to be a gap even with the newer style column trim.or should i just replace the whole column with a non-tilt steering column
FWIW, Frankenstang's Capri has the column from a '90 Mustang but a steering wheel from an '87-'89 on it. It technically fits and functions - it'll fit on the splines of the shaft and steer the car - but it's a huge PITA because the older steering wheel fits too close forward and your fingers are constantly hitting the turn signal lever when you turn the wheel. I believe the '90-'93 column is an inch or two shorter to make room for the thicker/deeper airbag steering wheel on those years.
Frankenstang's reeeeeeeally wanting a Grant steering wheel to replace that '87-'89 wheel, and I reeeeeeeally want to ditch that Ford Tempo lookin' wheel in my '84. I'm thinking we can work something out... ;)
I thought we had already established that deal? :scratch:
I hope they have some kind of spacer so the wheel will be out where it's supposed to be.
