Theoretical Question
  • Thread starter Thread starter Mush-Hog
  • Start date Start date Jul 7, 2009
M
Mush-Hog
South Carolina
Jul 7, 2009
  • Jul 7, 2009
My 96 gt is an automatic. I have basic bolt ons now, tuner, exhaust, h pipe, intake, plenum, t body, pi manifold. I have the stock 3.08 gear in the axle. I am on 245/45/17s. (Nitto 555Rs)If i am on flat ground and mat the gas the tires will turn over a few times and then launch like crazy.
If/when i put 4.10s or 4.30s in should it roast the tires off instead of just rolling them over a few times? I want to be able to mash the throttle and the tires just roast, or come into a haripin lay the gas to it an powerslide a bit, and spin some mean donuts too.
Not looking to win the 1/4 mile trophy, just a fun sideways machine.
BTW i have a spool, so it is locked, no right tire fire.
I am having a hard time choosing, leaning toward the 4.30, due to a plan for a bit bigger cam profile b/c i dont wanna be taking the tranny out anytime soon to swap to a higher stall converter.(2k on fresh build) I hate messin with the tranny.
Any other input,suggestions or past experiences GREATLY appreciated!!!!
02nightmaregt
To hell with your Mustang, I want to see your HOG!
Jul 1, 2007
513
Southern Indiana
Jul 7, 2009
  • Jul 7, 2009
Man i think(just my opinion) 4.30's is a bit much especially in a npi.
VEE EIGHT
85
Texas
Jul 7, 2009
  • Jul 7, 2009
4.30's are overkill for a non-PI 2V IMO
T
TGJ
1,049
  • Jul 7, 2009
A couple of questions:
1) Do you drive a lot on the highway? If you do, you probably want to reconsider 4.30's.
As for 4.30's being too much for a NPI auto, I have 4.30's in my 96 TBird and have ran them for over 4 years. When I put them in my car, all I had for mods was a custom dual exhaust, PI Cams, PI Intake, Steeda UD pullies, 3800 RPM Stall TC and a SCT tune. They were not to much gear for that car as it still made 24 MPG on the highway. My car is quite a bit heavier than a Mustang though. If I were to do that all over again with that car and those mods, I would do it again. Do not fear the gear...
2) You do realize that the stock TC stalls between 2400 - 2700 RPM? Just curious as to why you want a TC with less stall?
RedDaemon
3,470
9
108
Atlanta, GA
Jul 8, 2009
  • Jul 8, 2009
i thought aero gt's came with 2.73's?
248a
Phoenix, AZ
Jul 8, 2009
  • Jul 8, 2009
No you could also get 3.08s and 3.27s. Mine happens to have factory 3.27s, which is why I know.
Blackone51
201
  • Jul 8, 2009
I have 1998 gt with 4.10s, ported heads, pi cams, and pi intake with an auto and I can't roast the tires per say but peel a little bit. All I can say is you get up to speed alot quicker with the 4.10s, it launches. I have some nice tires though so maybe with some cheap tires you can roast them with the 4.10s. I can peel a little bit smashing the pedal at 40mph which could never do before.
M
Mush-Hog
South Carolina
Jul 8, 2009
  • Jul 8, 2009
I do not want a converter with less stall i just dont want to need to install one with higher stall to copensate for the cams powerband. so i was thinking deeper gears would help get it into the power quicker with a higher lift cam. No highway driving too often mostly the redlight district or country roads.
RedDaemon
3,470
9
108
Atlanta, GA
Jul 8, 2009
  • Jul 8, 2009
Engine Gas in my oil
  • limp
  • Jun 15, 2025
2K
Fox 5.0 Mustang Tech May 16, 2026
Mindseye007
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
Help with AFR reading
  • dz01
  • Nov 14, 2024
1965 - 1973 Classic Mustangs -General/Talk- Jan 8, 2025
GOvert
G
Progress Thread Giving an abandoned 88 GT project a new chance at life
  • jaketractor
  • Jan 9, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2025
