So i hear this tapping noise from under the hood. you can barely hear it but since i know my car well, i knew the tapping wasnt there before. anyway, im thinking worst case scenario i have to adjust a rocker or maybe even debris is causing the noise down there. Anyway, for no reason i decided to just tighten my header bolts on that side of the motor, 3 of them were VERY loose. i was kinda worried and when i took a closer look at the header gasket it was torn pretty bad where the tapping is coming from. it was also a little bit burnt. is this tapping just exhaust leak and i should replace the header gasket? thats what im thinking, someone please reply.
