Thermactor plug
  • Thread starter Thread starter 281pony
  • Start date Start date Nov 15, 2004
281pony
2,681
Oly, WA
Nov 15, 2004
  • Nov 15, 2004
im about to start my new engine for the first time and im going over everything. yesterday i bumped it a couple times to make sure it was going to turn over. just two quick bumps.
on my passenger side head, the thermactor plug on the front of the engine is missing where the bracket bolt goes. will the absense of the plug cause a major airleak?
just wondering, i heard some compression hissing out after the bumps i think and thats the only leak i can really think of it would have. i tried to feel around but it goes just as deep as the screwdriver tip i was using, are they just straight through or will it cause an airleak?
thanks
bmorrisj
449
Buena Park, CA
Nov 15, 2004
  • Nov 15, 2004
yes i would plug it, thats how smog pump air gets in the heads....
281pony
2,681
Oly, WA
Nov 15, 2004
  • Nov 15, 2004
the rear is plugged already.
the front is what im wondering about. does it go straight through the head completely?
i can get a plug eventually reguardless, its just right now i dont have transportation until my car is up and running. i dont want a massive airleak now and im trying to get something resolved before first startup.
bmorrisj
449
Buena Park, CA
Nov 15, 2004
  • Nov 15, 2004
well technically there is no front or back to the heads, they are both the same, you can install them any which way you want ... the thermactor holes/plugs are there really to just thread bolts into the heads(front brackets) or for the crossover tube (rear emissions)
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Nov 15, 2004
  • Nov 15, 2004
You will have a leak at the front because as stated there isn't really a front or a back...the holes match on both sides...
Put some silicone on them when you install them and "twist" them in until they stop...
You will need the plug in the front anyways because the inside of the thermactor plug is the size threads you need to put your alternator bolt/power steering stud in...it will not thread in without the plugs...
They "plug" up the hole where the smog equipment goes (the same thing works for the front of you heads...you can get them at a Ford Dealership - part # F4ZZ-6E086-A or you can buy some from Summitracing - part # TFS-51400265...when you put them in the front of your heads your alternator bolt and power steering stud will screw right in perfectly...when I first seen they were to the heads hole threads were to big doing my h/c/i swap...I thought I put the heads on backwards
  • Mindseye007
  • Aug 16, 2026
Mindseye007
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
