Thermostat Issues
  • Thread starter Thread starter Foxfirst846
  • Start date Start date Mar 28, 2017
F
Foxfirst846
87
  • Mar 28, 2017
So I am falling into previously discussed issues.. I have a bolt broken off in bottom of the intake. Housing has been removed. I tried drilling it out with an easy out too. My question is this; Can I use in weld or something along those lists bed to glue the thermostat housing to intake. I'm just trying to get through this year before rebuilding engine with new parts. Any advice us greatly appreciated!! I'm gonna try again to remove the bolt. But looking at other options if I can't get it out..
General karthief
Mod Dude
Aug 25, 2016
28,133
10,751
213
polk county florida
Mar 28, 2017
  • Mar 28, 2017
What intake are you using? Maybe some pics?
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Mar 28, 2017
  • Mar 28, 2017
helicoil but as mentioned show some pics
90sickfox
Wasn't a pretty sight...and I've got big hands
Mar 2, 2015
6,953
5,831
213
Mar 28, 2017
  • Mar 28, 2017
Uh oh ! Are you talking about the lower thermostat housing bolt....the one you can't get a straight shot to ?
The easiest way I found to deal with a broken bolt there is to pull the accessories, and timing cover...then you can get straight to it. It'll have to be drilled out straight and tapped or helicoiled.
You could always pull the intake but that's more of a hassle to me. My intake gaskets aren't stock though...so I would opt for replacing a cheap timing cover gasket over having to order new upper and lower intake gaskets. Either way it's a lot of work.
I don't know of a glue that will hold the heat and 16 to 18psi reliably.
Reactions: General karthief
Mustang5L5
Mod Dude
Feb 18, 2001
43,375
18,122
224
Massachusetts
Mar 28, 2017
  • Mar 28, 2017
What type of manifold is it?
If stock or gt40, I'd just pick another lower up and plan for a quick lower swap on a sat morning
I would t trust driving on some sort of temp repair that isn't a drill/tap or helicoil
F
Foxfirst846
87
  • Mar 28, 2017
Thanks everyone for replies! I have the edelbrock 5.0 performer upper and lower intake I think lower says 3820 on it. Yes it's the lower bolt I had no problem getting to it. But when tightening down I snapped it. I tried to drill it out and retap it. However I went in crooked. So at this point I think my options are to weld it on for a permanent fix. Or maybe some jb weld to last this summer till I rebuild in the fall. I think if I put a hell coil in there I risk snapping lower intake as it's pretty thin already... Thoughts??
D
Deleted member 215073
Mar 28, 2017
  • Mar 28, 2017
Replace the lower intake. I wouldn't trust JB Weld to hold. And to weld the thermostat housing to the intake would require removal of the lower intake anyway. I would also buy a torque wrench and make sure you use the correct torque specs when tightening the bolts down next time. It also helps to use anti-seize on the bolt threads to keep them from corroding.
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Engine New factory manifold no start
  • Fishnchips
  • Oct 15, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Oct 22, 2026
DadLife0724
9
1994 Mustang GT 5.0 L Convertible
  • 94ns95
  • Jun 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 19, 2026
94ns95
9
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
