Thermostat testing
  • Thread starter Thread starter Celeb
  • Start date Start date Jan 18, 2010
Celeb
20+ Year Stangneter
Sep 8, 2002
736
Here and there
Jan 18, 2010
  • Jan 18, 2010
So after a cam swap, my car starts overheating. With car warm, upper radiator hose as well as lower radiator hose stone cold. Radiator as well, and heat stopped working. (Well it comes and goes) When the heater rarely works, the engine temp cools off but goes back to cold when engine runs hot.
Bench tested the old one and while it opened, it seems to barely open, maybe 1/8". New one opened almost twice that.
Haven't cranked the car yet, waiting for some permatex to dry. Probable culpret though based on the symptoms?
timeless2
Vi Veri Veni Versum Vicus Vici
Admin Dude
202
154
the Shadow Gallery
Jan 18, 2010
  • Jan 18, 2010
No heating issues whatsoever prior to the cam swap?
Celeb
20+ Year Stangneter
Sep 8, 2002
736
Here and there
Jan 18, 2010
  • Jan 18, 2010
Nope, heater worked fine and engine remained cool. Perhaps some type of debris made it's way to the tstat while I had the engine open (scraping off old gaskets etc) Installed a new water pump as well. Old one worked but it made an awful racket.
timeless2
Admin Dude
202
154
the Shadow Gallery
Jan 18, 2010
  • Jan 18, 2010
Next, check for air in the system. Burp time.
Celeb
20+ Year Stangneter
Sep 8, 2002
736
Here and there
Jan 18, 2010
  • Jan 18, 2010
Hopefully the new tstat fixes it. If not I'm worried that my new water pump isn't moving water. I'm wondering if there's a bench test for that. Maybe pull the smaller hoses off the top of the pump and get someone to bump the engine?
Good call on burping the system also.
timeless2
Admin Dude
202
154
the Shadow Gallery
Jan 18, 2010
  • Jan 18, 2010
T-stat is an easy, cheap fix...if it's truly the culprit. Rule out those really easy ones first, then go from there.
HISSIN50
34
129
Jan 18, 2010
  • Jan 18, 2010
If you don't have one, a burping funnel makes burping the system a little easier and a smidge safer. I always run the cars for a bit with no rad cap installed (this is where the funnel can help). Otherwise the buried air has a tough time surfacing.......
I also like Tim's thoughts on the stat. FWIW, air in the system can damage the pellet (especially true on a non-balanced stat). That could be another reason the old one went south.
Good luck bud.
D
Resolved Upper radiator hose cold??
  • dqureshi06
  • Oct 31, 2024
2K
Fox 5.0 Mustang Tech Nov 11, 2024
limp
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
O
2001 mustang gt overheating
  • orinsmiley11
  • Jul 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 17, 2025
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
Resolved Got Too Hot!!!
  • PonyGTrider
  • Apr 27, 2025
Fox 5.0 Mustang Tech May 6, 2025
PonyGTrider
