  • 1994 - 1995 Specific Tech
Thermostat?
  • Thread starter Thread starter Irrational
  • Start date Start date Mar 25, 2006
I
Irrational
26
Neptune NJ
Mar 25, 2006
  • Mar 25, 2006
Hey guys just finishing putting my car back together. Started it up last night for the first time. Car ran great then started to heat up. I was burping the coolant. But thermostat just would not open. Anyone have any ideas or walkthrews I could look threw to double check myself? Any common problems people come across changing out there thermostat to a 180?
bill302
2,131
alabama,gadsden
Mar 25, 2006
  • Mar 25, 2006
pull the thermostat and test. you should test every thermostat before installation heres how to do it you will need a thermometer that is capable of reading the specific rating of your thermostat you can purchase these at wal-mart or any parts store at fairly reasonable price about $5 You can test a thermostat by putting it in a pan of water and heating it up. You use a thermometer to see at what temperature the thermostat closes and opens up, and then you match that to the thermostat's ratings.if it doesnt open or close at proper temp. replace it and test new one before installing. also i would not use any thermostat unless it was a stant superstat or mr. gasket....goodluck and post results.. also check thermostat when you remove it it can be in backwards the spring on thermostat should inside housing attached to the top of the motor. if the spring on thermostat is inside the waterneck housing thats removed when replacing its in backwards this happens alot and goodluck...
HISSIN50
34
129
Mar 25, 2006
  • Mar 25, 2006
How did you burp the coolant if the stat wouldnt open?
In addition to Bill's very helpful post, are you sure the system is fairly full? If steam pockets travel to the top of the system when the stat is closed (the top is arguably the stat itself), the steam will banter the back of the stat. This alone can damage the stat beyond being reliable anymore. A balanced stat has a shrouding to help mitigate this abuse.
If the stat tests ok, make sure the system is full and that you have a jiggle valve/hole in the stat.
Good luck.
I
Irrational
26
Neptune NJ
Mar 26, 2006
  • Mar 26, 2006
Thanks guys. I already had got it. stupid mistake I had It air bound behind thermostat so wouldn't open. Also I was not burping it i was attempting to.
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
Resolved Got Too Hot!!!
  • PonyGTrider
  • Apr 27, 2025
Fox 5.0 Mustang Tech May 6, 2025
PonyGTrider
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
