i will do the instal tomorrow.70mm Accufab TB + plenum. What do i need to know before i do it?? anything will be helpful
pointers from people who already did the instal by themselves would be greatly appriciated.
i would go get replacement bolts for TPI. because you'll mostlikely mess'em up. U might want to know where you can get multi-meter just in case you don't install TPI right, and ran in to idle issue.
remenber to disconnect batt. and you be sure to remenber usualy it takes car to few days to relearn idle sequence. so right after you install it, and car doesn't run right, be patient
okay thx Mity2. But what is TPI?.I never messed with TB's so i will try my best to be patient and unscrew things with alot of care so i wont mess up things.And what is "multi-meter" and what does that do ?
and can someone tell me the best way to do the instal withought runing into problems and having to buy extra parts as mity2 stated
i mean to say TPS... lol I was helping with wireing on my neigbor's Camaro earlier today.
Throttle Position Senser - Its the black plastic senser thats bolted to TB. It reads Voltage - anywhere from 0.94v~5.0v depending on how much throttle blade is open. ECU gets signal from that to carculte amount of fuel it needs to run.
You might be able to bolt it, and get iot right the first time. But if it doesn't, then you need to mess with it. its not that hard really if u have Volt meter. its prolly take 10 min if you have to mess with it with meter
I just recieved my combo less then 30mins ago.Just looking at it makes me happy
i looked under my hood , and i think it will take much more effort and patience then i thought I hope i'm good for it.
I will keep you guys posted with the results. I will do the instal tomorrow i think. Gotta go to work now
