Is all I need to do is prime the engine...how do I know it is primed (valve covers are going to be on)...also how many times do I need to manually turn the engine over while priming?
I will get it started tomorrow once we figure out why my headers aren't lining up...I can get about 5-6 bolts threaded in on each side but I can't get the last two bolts in because it seems to be to short (AFR 165 heads by the way)...so I got a couple guys coming over tomorrow to help out...any ideas?
Went a bit off topic there...but you all got any ideas what I need to do...?...also a dumb question here but how do I know when the radiator is full...also...I'm installing a Griffin radiator and I don't have time to go get a new radiator overflow tank...what will it hurt if I don't drive with it on...???
Thanks,
David
Thanks,
David
Whats the exhaust specs? Duration? PM me if you dont want all of stangnet knowing. Should run good.
...and about checking the clearance...well I did it but I didn't...I went ahead and did it with the heads on and used a welded up old HR lifter (temporary solid) and when I took off the heads my "intake clay" was all over the place" (looks like I didn't put enough oil to keep if from sticking to things and it was just to torn up to get an accurate measurement...the "exhaust clay" was readable and was fine (no clearance issues)...and me getting frustrated and it being near the end of they day called it quits on checking the clearance and went on with the install
...I don't know what I was typing...
