thinking about buying a 95 gt..
augusta
53
augusta, ga
Here is a description of it, what do you guys think? It hasnt been dyno tuned, but if I get it I'm going to take it straights to t&j to have it tuned, Is there anything you would have done different if it was yours, and anything that I should do to it, or wether or not its a good setup.... I have an 01 bullitt, I dont know a lot about the 5.0's...
"All the Parts listed below have less than 3500 miles on them!! DSS Racing 306 pro bullet www.dssracing.com gt40x heads cobra upper and lower intake Mac Cold air kit pro-m 77 mm mass air calibrated for #24 injectors 24# svo injectors 65 mm ford motorsports thottle body walbro 255 fuel pump BBK fuel pressure regulator Ford Motorsports x303 cam at.050" lift, int. 224 deg, exh. 234 deg, I/E lift is .542 1.73:1 dss roller rockers bbk shorty headers off road mac h pipe (bassani catted x pipe also) flowmaster 2 chambers msd ignition 6al blaster coil lowered with ford motor sports springs 1.5" sub frame connectors bbk camber plates 3.55 gears strange axles every part under the hood except for the power steering pump and a/c pump is new A/c has all new o rings and was vaccumed down and checked for leaks and then recharged raditor,water pump, hoses etc replaced.... you name it its new recently replaced shocks new tires new clutch comes with 2 extra wheels and a new clutch quadrant still in the box!!"
Thanks.
well, technically his HCI is already done. Im not favoring the cam or heads on there. Port the cobra lower. Just send it to TMoss. HCI refers to our Heads, Cam, and Intake. Thats pretty much giving you a 12 second car NA.....and 13 sec driver :rlaugh: jk. i like the tag on it. the 306 is pretty torquey with those mods there. Although, if/when you buy, get a heat gun and get those pin stripes off.
