Thinking about this setup
  • Thread starter Thread starter rcmustang17
  • Start date Start date Jun 18, 2009
R
rcmustang17
  • Jun 18, 2009
Hello, I am thinking about this setup for a budget street car build. Currently my car is completely stock but I am planning on getting 3.73 gears within the next couple of weeks and then this H/C/I in a couple months
Edelbrock E-Street #5023 Heads
Edelbrock RPM Intake
TFS 1 cam
Do you think this combination of parts will work well together? I am hoping to get around 260-280whp it just needs to be DD friendly. I was thinking about using the Edelbrock performer cam #2122 but havn't heard much about it, does anyone hear use it? How do you like it? Or do you think it would be worth it to just get a custom FTI cam?
Stopsign32v
394
Gville, SC
Jun 19, 2009
  • Jun 19, 2009
That is a horrible combination IMO. Your best bet would be to look for some used AFR heads or Trickflow twisted wedge heads. Get you a Edelbrock RPMII intake and have Jay Allen grind you a camshaft once you have everything. I had Jay grind me one when I had a stock shortblock and the car cammed hard enough to make people inside a store look outside and I could still cruise at 1,300rpms in 5th gear without the car bucking. Stay away from Edelbrock heads unless they are the CNC ones. That is my opinion. No one makes a better intake than Edelbrock though.
ProKiller
3,064
15
78
PA
Jun 19, 2009
  • Jun 19, 2009
the rest of the combo isn't too bad but those heads are a no. either afrs or twisted wedge. those heads are too small to really grow. take it from someone who knows small eddy heads
Killercanary
The car that set the bar.
Altoona, PA
Jun 19, 2009
  • Jun 19, 2009
I won't bash those heads yet as I know they are a brand new casting from edelbrock and they come in under $1000 for the set if I remember correctly. They are an entry level head, but I haven't seen any flow data from them yet. I know they have a 170cc intake port though. If I had to run those heads I'd put an edelbrock performer intake on it, a set of long tubes, and a cam that made peak power in the 5500rpm range. It'd a good mild street setup that should hit all of your goals. I'm running an FTI cam and I can't say enough great things about Ed.
R
rcmustang17
  • Jun 19, 2009
If I went withAFR's would I want the 165's or 185's?
Killercanary
Altoona, PA
Jun 19, 2009
  • Jun 19, 2009
You'd want stud mount AFR 165's with the 58cc chamber. Don't buy pedestal mount heads as stud mount are easier to adjust, setup, obtain proper geometry, and have less defelction under higher spring loads and engine RPM.
185's use a 2.02" intake valve and you will have piston to valve clearance issues with them on a stock shortblock. I ran 165's on my stock shortblock and for a while on my 331. They are a great head.
F
Best plugs for carb'd roller
  • forango
  • Nov 21, 2025
  • 2 3
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 2, 2025
HotFox
C
Fox Need help identifying brake setup
  • Cypher02xd
  • Apr 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
Mustang5L5
T
Rpm vs rpm2
  • thor347
  • Mar 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 19, 2025
thor347
T
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
351w turbo build.... Turbo guys teach me things...
  • Kid wita 5oh
  • Oct 22, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 23, 2025
General karthief
