  • 1994 - 1995 Specific Tech
this is a first for me
  • Thread starter Thread starter fast94mustangGT
  • Start date Start date Aug 9, 2006
1 of 2 Next Last
fast94mustangGT
60
  • Aug 9, 2006
well i was checkin my oil last night and it was alittle low, no big deal. so i went take the oil cap off and it was alittle tight, and while i was trying to unscrew it the damn thing broke off in my hand.... the threaded part is still in the valve cover and it sticks up maybe a 1/16" of an inch. dosnet leak of spray everywhere but now i cant put the oil in it needs..........
so uh..any ideas how to get this son of a bitch out?
ProKiller
3,064
15
78
PA
Aug 9, 2006
  • Aug 9, 2006
take of the valve cover off for starters, then you can work on it more. vise grips?
fast94mustangGT
60
  • Aug 9, 2006
yea i figured i would have to pull the valve cover, damn everytime i get ready to fix one thing another breaks...err
oh well ***** happens i guess
1TallMF
955
Montreal
Aug 9, 2006
  • Aug 9, 2006
I wouldn't jump the gun and take the valve cover off just yet. Surely there must be a way to turn it with channel-lock pliers or vice grips. It really shouldn't be on that tight. If not, I'd try drilling a small hole near the outside (not through it, so that plastic bits don't get into the engine) then use a small punch or screwdriver with a hammer to try and unscrew it by tapping it. Good luck
1TallMF
955
Montreal
Aug 9, 2006
  • Aug 9, 2006
You could also be lazy and take the half-@$$ed approach of unhooking the pcv hose from the filler neck and adding oil through that orifice using a funnel and a piece of hose.
fast94mustangGT
60
  • Aug 9, 2006
well its tight, very tight. it broke because i was appling so much force to unscrew it. hope that **** isnt stuck down in there.
fast94mustangGT
60
  • Aug 9, 2006
lol hey i didnt think of adding oil like that atleast i can get some in it though
donjohn
1,757
Irvine - Southern California
Aug 9, 2006
  • Aug 9, 2006
what about cutting a slit in it and using a screwdriver (one with a large, or at least wide bit)... but if you go all the way through, you could accidently get crap in there.
i've never removed the valve cover, but i'd probably do that.
RIO5.0
6,892
N.H.
Aug 9, 2006
  • Aug 9, 2006
How about drilling 2 holes 180 deg apart...put pins in them and use a screwdriver across them to turn the mother out??
slvrbullit302
986
Alabama
Aug 9, 2006
#10
  • Aug 9, 2006
  • #10
I had this problem before as well, inside the cap at the bottom there are some notches that give the cap the rachet sound when it is tightened too far. I used a screw driver or a pair of needle nose pliers and wedged down in there to turn the cap.
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
Aug 9, 2006
#11
  • Aug 9, 2006
  • #11
Im thinking this is your best bet.
68torinogt
Hey guys, guess what--I have a bi-pass!!!
Mar 21, 2006
Welcome my son, welcome to the machine
Aug 9, 2006
#12
  • Aug 9, 2006
  • #12
i have got to see this
bidg1withmyson
#13
  • Aug 9, 2006
  • #13
usually what we run across at the shop is the o-ring seizes to the cover/filler cap one way we have had to get them out is to break (by what ever means necessary) the top portion of the filler cap off to where you can get acess to the o-ring and pull it out. usually once it is out the remaining threads will spin off with ease....then the remainig threads usually go sailing!!!!!!!!!!! hope this helps good luck
fast94mustangGT
60
#14
  • Aug 9, 2006
  • #14
allright while at my dads today i got it out with some channel locks. wasnt to hard to get out so that was cool.
and sorry for no pics my dog chewed up the usb cable for my camera
fast94mustangGT
60
#15
  • Aug 9, 2006
  • #15
oh yea also noticed today that i have a small oil leak coming from my oil pressure sending unit
STANGateURlilSS
716
USA & SANDBOX
Aug 10, 2006
#16
  • Aug 10, 2006
  • #16
thats the stupidiest thing i have ever heard... they may to retarding things like that in canada... but here in the usa... we do things right...
1TallMF
955
Montreal
Aug 10, 2006
#17
  • Aug 10, 2006
  • #17
hahaha ouch!
I made a mistake. To make this a truly canadian fix, you'd have to duct-tape the hose to the filler neck and use a beer can as the funnel. But you could also poor oil into the open part of the broken cap and light it on fire to melt it away.
For the record, this is all BS. Canadians never do this kind of stuff before the southern rednecks try it first. Only then can a method be tried, tested and true
Therian
The Highlander
Waterloo, Ontario
Aug 10, 2006
#18
  • Aug 10, 2006
  • #18
donjohn
1,757
Aug 10, 2006
#19
  • Aug 10, 2006
  • #19
Ok, if it's such a stupid idea, care to explain yourself...
here on stangnet, people don't like bashing others... especially when there is no argument to back it up.
In a pinch, I don't see why this wouldn't work even though it's a little thrown together. I mean, I wouldn't do it and just take the valve cover off if needed, but in an emergency
1TallMF
955
Montreal
Aug 10, 2006
#20
  • Aug 10, 2006
  • #20
:Word:
1 of 2 Next Last
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
5.0 Rebuild
  • smittys7up
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 16, 2026
keel
9
96 mustang gt
  • 96projectgt
  • May 2, 2025
  • 2 3
2K
1996 - 2004 SN95 Mustang -General/Talk- May 15, 2025
96projectgt
9
V
Engine Antifreeze in oil
  • vinzo
  • Oct 9, 2024
Fox 5.0 Mustang Tech Oct 10, 2024
vinzo
V
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
