this is different
  • Thread starter Thread starter PIMTOUT
  • Start date Start date Apr 23, 2004
PIMTOUT
298
9
kingsford,mi
Apr 23, 2004
  • Apr 23, 2004
on a 302 why would all the lifters on the pass side of the car be mushy ( you can push them down easy like no oil in them) and on the drivers side they are all stiff like all pumped up....i just noticed this as i was adjusting valves....doesnt seem right........need imput......
PIMTOUT
298
9
kingsford,mi
Apr 23, 2004
  • Apr 23, 2004
man i really need so input guys
cjones
1,561
Avondale, AZ
Apr 23, 2004
  • Apr 23, 2004
did you just put the engine back together?? if so, what did you do??
new lifters may be "mushy" because the oil has not pumped them up yet.
when you adjust the valves you tighten the rockers until you get some resistance while twisting/spinning the pushrods then go about 1/2 - 1 turn or torque to specs within 1 turn (depends on type of rockers)
PIMTOUT
298
9
kingsford,mi
Apr 23, 2004
  • Apr 23, 2004
i got about 3000 miles on it, its just loud..ticking..so i adjusted the rockers using ed curtis method....the weird thing is that on the pass side of the car i was able to do the 3/4 past 0 lash with my fingers, and on the drivers side i had to use a wrench..and now that they are all adjusted the ones on the pass side you can push the rockers down to make the lifters compress, and on the drivers side they feel solid and dont compress by pushing on the rocker arm....to weird.....im calling dss on monday to see what they say...just seems weird that one side of the engine would be like this and the other isnt. almost like one of the oil vally plugs came out in the timing cover area? if thats posible.
PIMTOUT
298
9
kingsford,mi
Apr 24, 2004
  • Apr 24, 2004
ttt
PIMTOUT
298
9
kingsford,mi
Apr 25, 2004
  • Apr 25, 2004
no one has ever had this happen?...help
M
motrV8ed
31
Hampton, VA
Apr 25, 2004
  • Apr 25, 2004
I'd see if I could pirate a set of stock lifters and replace them on the passenger side to see if anything changes. Could have some worn lifters, not sure why it's just the passenger side though.
PIMTOUT
298
9
kingsford,mi
Apr 25, 2004
  • Apr 25, 2004
i might just replace them all but i dont know why they would have went bad in the first place only a couple thousand miles on them
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
D
351w swap shifter is not lining up
  • duckman0926
  • Aug 6, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 7, 2025
limp
