Hello I have been considering upgrading to this setup for a while now. I have cobra calipers now and after every track day I have to rebuild the calipers because there is nothing left of the dust boots. I also require a more rigid caliper, for pad wear issues and pedal feel. I have been reading that I can reuse my current braided cobra hoses with the brembo calipers. Is this true? I see that buyfordparts.com has the calipers and pads only. I want to know if I can just buy these parts and not the whole kit. Also, what kind of pads does the kit come with? This is very important to me because I dont want to pay for "high performance street pads" that I will just set fire to and toss out on my first track day. Also, does anyone know if anyone sells these calipers as a set w/o pads. I ideally would like to run pads of my own choosing.
. Ceramic pads are a joke, they wont take the heat of a race pad and since ceramic is a very good insulator they dont dissipate heat very well (since they dont absorb much) leaving your rotors to do all the cooling. Slotting is also a joke, unless you run really crappy pads that gas out or you dont bed your pads properly, cross-drilling is even worse as it further reduces the strength of the rotor. Currently the rotors are running up to about 1250-1300 deg F. (measured w/ hi temp color change paint), I need a pad that can stay with me at those temps, or possibly slightly less with the brembo calipers as the pads are larger.
:Zip2:
