- Feb 18, 2003
- 1,068
- 0
- 36
i have a few questions. theres a guy selling a used "kit" here in town and he said everything is included except the FMU. what exactly is included in the kit? also, i know this has been covered a hundred times, but can i just slap a s/c kit on an otherwise stock car, get a safe tune, and be ok? i tried a search for this, but couldnt find anything. thanks for the help, mods in sig
what other supporting mods might i need? fuel pump? the kit is supposed to come w/ injectors, i just hope he has them. i asked him what was included and he said "everything but the FMU, head unit, bracket, everything". it sounded a little shady, but i'll go check it out. he also has the 10# pulley on it
) Worst case you will need a fuel pump, injectors, and may need to tap into your oil pan. Ofcourse you will need a tune too. Um i would also buy a 8PSI pully if its not intercooled. 10PSI is going to make alot of heat and PERSONALLY I would lower the boost a tad. However there are people that run 10#s W/O an IC. But if you stay shy of 400 then it will last a while, granted your not beating on it. Look for around 330RWHP on Jims dyno.
