thoughts on a mini spool?
  • Thread starter Thread starter jlangholzj
  • Start date Start date Oct 8, 2008
jlangholzj
Mustang Master
Oct 23, 2006
248
31
93
MI
Oct 8, 2008
  • Oct 8, 2008
I know i know.......
they wear the tires more.....not as nice going around corners......hard to turn tight
I've dealt with this in a 4x4 F350 before...
anyway...other than the above gripes, is there anything else i should know about? Being on a college budget, i REEEAAALLYYY want that locking rear end, but i was cursed with a 8" rear
are there any of you guys out there running a mini spool? how do you like it, or what are your thoughts.
I guess my car doesn't see a whole lot of inner city-turning corner driving, so I'm not as concerned with that. and I'm not buying Yokohama's for my car either!
57fairlane
560
Oakwood, GA
Oct 8, 2008
  • Oct 8, 2008
I wouldn't bother buying one . . . just make the stock open a lincoln locker.
I had a moser mini-spool, and thought it was a very good improvement over the "one wheel peel".
I would do it again for a weekend warrior type car, but not for a daily driver or anything you want to handle well in the turns.
jlangholzj
Mustang Master
Oct 23, 2006
248
31
93
MI
Oct 8, 2008
  • Oct 8, 2008
yup, not a DD thats for sure
lol, licoln locker as in weld 'em together?
10secgoal
2,801
San Diego
Oct 8, 2008
  • Oct 8, 2008
welding them can be very dangerous if it break. A good weld is pretty much impossible with how impregnated the metal is with oil. I run a full spool, not the mechanism to adapt to a spool. But I love it. I makes it a bitch to turn low speed, turning radius worsens, but I haven't burned one up yet.
blown65
1,938
Queen Creek Arizona
Oct 8, 2008
  • Oct 8, 2008
For a strip car a spool is fine, but even then I hate them. Push a car with one by hand and need to make a turn and you will find out what a PITA they are. LOL
dennis112
1,561
36
79
Amish Wonderland of Central PA.
Oct 9, 2008
  • Oct 9, 2008
I recently installed a full spool and the above pretty much sums up my street experience. Works great on the highway but sucks at slow speeds with hard turns. I understand that they are not good to drive in wet weather, but I tend to avoid that anyways. Mine is a weekend play thing that sees lots of track time and lots of street time and so the spool is acceptable to me. I wouldn't want one in a DD though.
I also agree with Blown65 as you will not want to push the thing with the wheels turned unless you tend to turn green and bust out of your shirts when mad. j/k
57fairlane
560
Oakwood, GA
Oct 9, 2008
  • Oct 9, 2008
that's how you can stop the car too if your brakes go out
You don't even need a block/emergency brake to stop the car on a hill, just turn the wheel
blown65
1,938
Queen Creek Arizona
Oct 9, 2008
  • Oct 9, 2008
haha, never thought of that. I'm probably changing mine to a spool when I change my gears.
brianj5600
1,964
Middle TN
Oct 9, 2008
  • Oct 9, 2008
I ran a mini spool in a street car and it was no big deal. It drove different, but not bad. They are cheap too. Check your local round track supply.
thexrcist68
63
Spotsy County, VA
Oct 9, 2008
#10
  • Oct 9, 2008
  • #10
ill let ya know how i feel about mine this weekend i'm installing one right now in my 8"
it was the numbers that got me to do it ~45bucks for a minispool and moly cross pin vs ~400+ for a locking type rear, it would be nice if someone made a full spool for an 8 though
jlangholzj
Mustang Master
Oct 23, 2006
248
31
93
MI
Oct 9, 2008
#11
  • Oct 9, 2008
  • #11
thanks! I'm actually thinking about designing a mini-spool type locker with a slot and pin that would allow it to turn ~3/4 of a rev. before locking in. That way it wouldn't be such a PITA around corners. I'm drawing one up now, and I've got the CNC equipment available here at SDSU, so I'll run it by an ME and see what they think.
T
tiptop
73
#12
  • Oct 9, 2008
  • #12
use a 6011 welding rod if you go to weld them spiders soild, 6011 = deep penetration.
thexrcist68
63
Spotsy County, VA
Oct 11, 2008
#13
  • Oct 11, 2008
  • #13
well i got mine in and so far so good, just takes some getting used to hearing the tires making noise every time i turn but other than that its alot better than the one wheel wonder that was there before, id say go for it
Z06killinSBF
457
McKinney, TX
Oct 13, 2008
#14
  • Oct 13, 2008
  • #14
I dunno if there is a difference between mini spools and full spools but my dad has a full spool in his Camaro and that thing is a PITA to drive. Long sweeping turns, slow movements, car hopping and bouncing on sharp turns (maybe that's the DR's...). Sure in a straight line it'll lay two even blacks but not worth it in my opinion.
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
Starters suck. So does the aftermarket!
  • Blue Thunder
  • Apr 30, 2024
5K
1974 - 1978 Mustang II Talk & Tech May 13, 2024
Blue Thunder
9
1996 Cobra convertible weatherstripping
  • 96 SnakeWild
  • Sep 5, 2022
  • The Welcome Wagon
The Welcome Wagon Sep 7, 2022
96 SnakeWild
9
