I'm looking to buy a new fox, and I've found one that looks really clean, but I wanted to get some thoughts on the setup. The seller says it makes ~600hp, but I'm not sure if that's at the wheels. He also says the engine work was done at the Muffler Shop by Brian and Chris Tuten in Columbia, SC. Anybody know of that shop? The mods are below:
DSS sportsman block. 347 stroker kit, eagle, crank, rods, pistons
edlebrock performer aluminum heads
roller rockers
procomp cam
holley system max 11 upper and lower intake
80 mm holley throttle body
holley egr spacer
msd ignition
pro flow maf 70 mm
373 gears
aluminum radiator, flywheel, drive shaft
sub frame connectors
tko tremec 5 speed
hurst shifter
king cobra clutch
long tube headers
x-pipe
flowmasters
aeromotive 5.0 eliminater fuel system kit p/n 17106
siemens 60lb injectors
aeromotive fuel pump controller
D1SC polished procharger stage 11 p/n 1fa324-d1sc (14psi) 12 rib
a lot of wires hidden under fenderwells of both sides of engine bay
complete UPR suspension front to rear. k member, coil over, upper/lower adj contol arms. sway bar. a arms
moser axle 35 spline with control unit
7 qt oil pan
Thanks
roller rockers
procomp cam
holley egr spacer
msd ignition
pro flow maf 70 mm
373 gears
tko tremec 5 speed
hurst shifter
king cobra clutch
long tube headers
x-pipe
flowmasters
7 qt oil pan
Thanks
