  • SN95 4.6L Mustang Tech
Throttle body-do not clean?
  • Thread starter Thread starter spederman
  • Start date Start date Feb 25, 2009
spederman
732
  • Feb 25, 2009
The twin butterflies on my TB are gunked up. I was going to use some TB/Intake Cleaner and ran across some info that the ford throttle bodies supposedly have a coating on the inside and ur not supposed to use anything on it or who knows what happens. Some TB's actually have a sticker saying do not clean. Anybody heard of this? Is it true, and if so wtf do i use to clean the butterflies?
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Feb 25, 2009
  • Feb 25, 2009
Take a rag with some carb cleaner and clean them up. I sprayed mine down so I'm not sure what the big issue is.
BurningRubber
1,865
24
58
Feb 25, 2009
  • Feb 25, 2009
Never heard of not cleaning one...
tag4car
Birmingham AL
Feb 26, 2009
  • Feb 26, 2009
done it on 4 totally different ford engines with no prob, used the spray u mentioned and everything
trinity_gt
3,125
81
99
Canada
Feb 26, 2009
  • Feb 26, 2009
FWIW, and it may not be much, there may be some validity to this. I used to have a Ford Probe with Mazda's 2.5L V6. Those engines had a very thin elastomer coating on the inside of the throttle body that was used to seal the throttle plate in the closed position. If this elastomer was removed, it could result in the engine RPM hanging and the idle becoming unstable as the removed elastomer, taken out by the solvent, allowed air to bypass the idle control solenoid. It wouldn't surprise me if this practice was more widespread among manufacturers.
What benefit do you really gain by cleaning a film of gunk from the throttle plates? If you were to flowbench a throttle body with and without gunk on the plates, I doubt you'd see an increase in CFM... Personally, I'd leave it. If the thing is really gunked up to the point where flow is being compromised in any way, you've got other issues to address.
[Edit]Further to this, my 2002 Ford service manual for my Mustang states, on page 303-04B-5, the following:
"CAUTION: The throttle body bore and plate area have a special coating and cannot be cleaned."
G
GettinThere
553
Central Texas
Feb 26, 2009
  • Feb 26, 2009
trinity_gt said:
...Those engines had a very thin elastomer coating on the inside of the throttle body that was used to seal the throttle plate in the closed position...Further to this, my 2002 Ford service manual for my Mustang states, on page 303-04B-5, the following: "CAUTION: The throttle body bore and plate area have a special coating and cannot be cleaned."
Do aftermarket throttle bodies have this coating?
streethorse
1,042
Dallas Texas
Feb 26, 2009
  • Feb 26, 2009
When I first took my FRPP TB out of the box I thought that it was used
allready since there was black stuff on and around the butterfly.
But yeah its a coating they spray on it.
trinity_gt
3,125
81
99
Canada
Feb 26, 2009
  • Feb 26, 2009
I don't believe my Acuufab did but I don't know for sure. Probably worth asking the vendor.
myponyrocks
I have more billet on the Stang than most women ha
Apr 18, 2004
1,219
Feb 26, 2009
  • Feb 26, 2009
I can confirm both Accufab and BBK TBs have the coating. Accufabs was a very small ammount, BBKs look like a blind guy applied it with a 4" paintbrush
trinity_gt
3,125
81
99
Canada
Feb 26, 2009
#10
  • Feb 26, 2009
  • #10
:SNSign:
Throttle body cleaning
  • dz01
  • Apr 29, 2024
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 2, 2024
EmmJay
E
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
2005 - 2009 Specific Tech Sep 6, 2025
Engine Coolant leak from throttle body
  • 91GTstroked
  • Oct 9, 2023
4K
Fox 5.0 Mustang Tech Apr 27, 2024
91GTstroked
R
Car shuts off under throttle, idles fine. Looking for some pointers.
  • rmarcotte
  • Jul 8, 2023
2K
SN95 4.6L Mustang Tech Aug 1, 2023
rmarcotte
R
