Throttle body help
timmy0257
I am contemplating replacing my throttle body in my 89. Will I need any additional hardware( EGR plate, gaskets, etc.) when I replace the stock 65mm with a larger 70mm TB? Currently, I only have the Cobra intake added.
yes you will need gaskets.you can buy the 70mm egr spacer or if you know of anyone that does machining you can bore the stock one to about 73mm or so.thats what i did and it will save you 50 bux or so
Be prepared to wrestle with the studs that hold the EGR spacer in place. They tend to corrode badly and can make remvoing the EGR spacer difficult. Home Depot, Ace Hardware or Lowes can supply replacement bolts.
I'd stick with a 65mm if you already have one. Also, a stock one isn't 65mm.
