  • 1994 - 1995 Specific Tech
Throttle Body Size
  • Thread starter Thread starter final5-0
  • Start date Start date Jan 15, 2007
  • 3
  • 4
First Prev 3 of 4 Next Last
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Jan 17, 2007
#41
  • Jan 17, 2007
  • #41
Black95GTS said:
Point taken! That doesn't account for an air filter though, does it? And that is a great site BTW.
If someone shows me real proof that they actually got faster and made more power by switching to a smaller TB, then I'll shut up. Slips, dyno charts, etc.
I'm loving this thread by the way, seems like we're actually trying to sift out some BS instead of arguing if 2300 RPMS in a 4.10 rear end is "too high for cruisin."
Keep it comin!:SNSign:
Adam
Same here I would love to see a 94/95 302-306 with the 94/95 induction stystem (this includes the EGR which 90-95% still have) gain from a 65mm/70mm/75mm.I would be more then happy to accept I was wrong and there is a gain with x amount of CFM through an induction that handles less CFM. Until then I see no reason to believe other wise. Great info lets keep the ball rollin.....
bimmertech
1,123
merriam, ks
Jan 17, 2007
#42
  • Jan 17, 2007
  • #42
here is my take on the situation.
i think you should go as big as you can without disrupting the engine's vacuum signal. i'm sure grady can recall the days of pulling out the vacuum gauge to tune the carb--on those flatheads of course
for instance---a '02 BMW 745 has what is called the N62TU engine. it is a V8 that has variable valve lift, variable cam timing and infinetly adjustable intake runners. it does have a throttle body, but the t/b stays open all the time and is there only as a fail-safe. it maintains idle and vacuum by varying the valve lift.
another BMW example is every M car made(cept the US spec E36 M3) uses individual throttle bodies per cylinder. the very first iteration M3 used a 2.3L 4 juicer that utilized 4 48mm throttle bodies---doing the math prolly equates to a much larger surface area than a 75mm t/b on an engine that is half the size of ours. it does not suffer any driveability and actually manages a decent amount of torque for an engine that revs to 7500.
basically i cannot see a drastic drop off in vacuum when you mash the pedal if you go to a 75mm t/b vs a 70mm. does that mean that the same would be true if you put a 90mm on? i don't know.
as for t/b's effecting wave pulses i can't see that happening as wave pulses are a result of everything after the t/b----ie cam timing, runner length, burn time, etc.... i think the habit we fall into is thinking that t/b sizes do the same thing as increasing or decreasing plenum sizes when in reality is they control vacuum and can act as a restriction at wot.
btw, POST #1000 bitches
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jan 17, 2007
#43
  • Jan 17, 2007
  • #43
Great info Ben
Congrats on the 1K post count
Grady
BlackVert
5,589
9
98
Bethesda, MD
Jan 18, 2007
#44
  • Jan 18, 2007
  • #44
Ben's talk about vacuum reminded me of something my engine builder told me. He said that if the induction system was correctly matched, then the vacuum reading at WOT would be in a certain range. If the value is above that range, then the induction system does not flow enough. If it is below that range, then it is too free flowing. Most of the engines he builds are for racing and use carbs, but he said that approach was also valid for determining the adequacy of the induction system on EFI engines.
And of course, vacuum is the determining factor in intake velocity, so it all seems to fit.
So perhaps that could be a way to empirically determine once and for all if a given induction system (throttle body size being a part of that mix) is correct or not.
Or perhaps there are 2 different target ranges: a part throttle vacuum range for a 100% street car, and a WOT vacuum range for a race car.
If we can agree on what those ranges should be, maybe there won't be any more arguing about throttle body size.
WhiteDevil
2,717
San Diego
Jan 18, 2007
#45
  • Jan 18, 2007
  • #45
Yeah that sounds pretty good
gcomfx.com
3,690
Republic, MO
Jan 18, 2007
#46
  • Jan 18, 2007
  • #46
I asked Don a similar question with my new combo. He said I should not just run out and buy a bigger T/B, but try the 65mm I have and see how it does with the new 331/Trick Flow setup. He mentioned plenty of higher horsepower (FI) cars on TurboMustangs running the same size T/B. Then later if I can get my hands on a bigger one, give it a shot and see how it runs.
Once I start spraying the car again, I should be able to test this even further.
blksn955.o
3,263
st.louis mo 314
Jan 18, 2007
#47
  • Jan 18, 2007
  • #47
Car Nut said:
blksn955.o mentioned a possibility of using a stock MAF from a newer stang to get very accurate results. Really? Almost seems too easy, but maybe there's more to it than what I see on the surface.
Its not just bolt on and go, you need to tune the eec with the proper maftransfer with a tune or tuner. People use the Lmaf/03cobra maf on 5.0's for more power why not a smaller version of the same maf then.
1. A good bit cheaper if one has a tuner that has access to the eec already over a Pro-m/PMAS.
2. Factory maf with a good known transfer that will be really accurate and in the proper format for the eec (no converting a 10pt transfer).
3. Ford made a few .
You will need the "new" style pigtail (and it isnt cheap) at around 45-60$, and an air filter adaptor of somekind...ebay has them for the Lmaf/older mafs in CIA kits and such.
gcomfx.com
3,690
Republic, MO
Jan 19, 2007
#48
  • Jan 19, 2007
  • #48
I just bought the pigtail for my Lmaf.... $25 at the Ford Dealership here.
BlackVert
5,589
9
98
Bethesda, MD
Jan 19, 2007
#49
  • Jan 19, 2007
  • #49
my builder says that for a racing application, if the vacuum is over 1/2" at WOT, then the induction system does not flow freely enough. of course, that means there is a restriction somewhere in the induction system, not necessarily just the throttle body.
if the induction system flows too freely (ie - it is too big), it will go below 1/4" at WOT.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Jan 19, 2007
#50
  • Jan 19, 2007
  • #50
Guys, in the vast majority of cases, the throttle body is not the weak link or restrictor in these N/A engines. I do not understand why people make such a big deal about getting the 'biggest and baddest.'
At 6,000 rpm a 347 can flow 600cfm. That is with NO restriction. Any 347 or similar has a ton of restriction. That cfm rating does not include a heads, cam package on it. The cam only is open for little amounts of time. So the cfm rating is further cut.
Guys are routinely sticking on throttle bodies that flow two to two and half times greater than their engine sees at it's peak.
I have to ask...why?
If you've got a throttle body that delivers 100% of the peak air requirements of your engine when the throttle plate is fully open, you have control of the air throughout 100% of the throttle position range. If you go to an oversized TB that delivers 100% of the air that your engine can consume while the throttle plate is only 60% open, you have given up usable throttle-control range for no advantage.
Guys that are constantly defending the oversized throttle bodies are only talking about wide open performance (WOT). What about the 99% of the time that we cruise around at part throttle?
Throttle modulation becomes more difficult. The gas pedal modulation becomes touchier.
Again, look somewhere else for a restriction, not an oversized throttle body.
An Accufab (for example) 65mm throttle body flows more than enough for a 347 stroker with 664cfm continously, while the 347 would see 600cfm if it had no heads, cam, or intake on it, which of course is impossible.
Enthusiasts need to quit ignoring the facts.
Read an article from the top throttle body maker themself and let them tell the tale:
http://www.accufabracing.com/article 3.htm
BlackVert
5,589
9
98
Bethesda, MD
Jan 19, 2007
#51
  • Jan 19, 2007
  • #51
good article, but i feel a need to point out that is does say that an oversized throttle body is not nearly as detrimental to lower and mid range performance as is an oversized carb, because of the way the carb needs air flow to properly mix fuel into the stream, whereas efi controls that via the computer.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Jan 19, 2007
#52
  • Jan 19, 2007
  • #52
Thats correct but there is no need to buy a bigger TB that cost more then buying the right one and spending less..
Car Nut
1,176
Snellville, Georgia (Atlanta area)
Jan 19, 2007
#53
  • Jan 19, 2007
  • #53
5sp GT: Nice article. That makes sense to me.
Of course, that leads to the issue of choosing the right filter, intake, MAF and inlet tubing. Probably the MAF is the more difficult, particularly with the typical swap to larger injectors.
Pokageek
2,767
MA, USA
Jan 19, 2007
#54
  • Jan 19, 2007
  • #54
:Word:
Black95GTS
1,644
Marlborough, MA
Jan 19, 2007
#55
  • Jan 19, 2007
  • #55
I can't find the post on here, it was a similar article about TB size, and the poster contacted accufab for advice for their 347 stroker. The accufab technician recommended the 75mm throttle body.
I'm going to keep looking, maybe some other peeps are better at it then I am?
There is a ton more then TB diameter that determines the flow into an engine. Just because the TB can flow 10000 CFM, do you really think thats the same amount that makes it into the combustion process? I don't.
Adam
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Jan 19, 2007
#56
  • Jan 19, 2007
  • #56
Adam
I know which thread you are talking about and you are correct the tech did recommend a 75mm for his stroker (don't remember if it was a 331 or 347). Which is against the arcle Klass wrote. And you answered your own argument/discussion why buy a larger TB if the motor can't get/use it. Your intake will fall in CFM before "smaller" TB's will.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Jan 19, 2007
#57
  • Jan 19, 2007
  • #57
Black95GTS here's the thread
http://forums.stangnet.com/showthread.php?t=673966
Also Black95GTS I think it was you who remebers the movie "Wolfman don't have nards" what is the name of that movie??
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Jan 22, 2007
#58
  • Jan 22, 2007
  • #58
Right, fuel/air atomization is a solid amount different with a carbed application over a throttle body.
Black95GTS - Not all tech's are perfect, and some are also marketing. I specifically recall George Klass himself saying that they sale "bigger throttle bodies" to those that think that is what they need, simply because they will buy them. He was speaking in general about unknowing import owners. The facts are facts. Accufab lays them out on paper. If you do not wish to follow, that is your choice.
I totally agree with you on there being more to it than just the diameter of a throttlebody to being the sole variable. That is my whole point exactly. Many go by diameter instead of cfm ratings. That is counter productive thinking.
wytstang is right on!
Black95GTS
1,644
Marlborough, MA
Jan 22, 2007
#59
  • Jan 22, 2007
  • #59
In terms of answering my own question, I guess the point I was trying to make is unless you can figure out the losses that occur throughout your intake track, and the needs of your combo, you're better off going with a bigger TB and hammering out the tune if it affects driveability and low end grunt.
I think this is a good thread cause we have avoided (and I'm guilty of it) starting to be a wise a** which frequently degrades a conversation.
So as always, performance comes with a price. If you want to bolt it on there and go, you might have to sacrifice some HP, but if you're willing to either work out your own tune or pay to have someone tune, you would consider the larger unit.
:OT: That's the Monster Squad. It's one of those B movies thats so bad its good.
Adam
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Jan 22, 2007
#60
  • Jan 22, 2007
  • #60
Monter squad thanks man I want to rent it for old times sake and yes this thread has kept on topic with no one flying off the handle.
  • 3
  • 4
G
Fox Tire Size for 16" Pony Wheels on 1984 LX Convertible
  • gw7
  • Jun 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2026
Qtrhrse23
Tire size question 1986 gt hatchback
  • B0udreaux
  • Jan 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 17, 2026
B0udreaux
J
Switched to e85 on the 3v and now it won't run right.
  • jcowdough
  • Aug 24, 2025
2005 - 2014 S-197 Mustang -General/Talk- Aug 24, 2025
A
need help and advise
  • amps1956
  • Oct 14, 2025
  • Other Auto Tech
Other Auto Tech Oct 21, 2025
Mcmahst
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
