Guys, in the vast majority of cases, the throttle body is
not the weak link or restrictor in these N/A engines. I do not understand why people make such a big deal about getting the 'biggest and baddest.'
At 6,000 rpm a 347 can flow 600cfm. That is with
NO restriction. Any 347 or similar has a ton of restriction. That cfm rating does not include a heads, cam package on it. The cam only is open for little amounts of time. So the cfm rating is further cut.
Guys are routinely sticking on throttle bodies that flow two to two and half times greater than their engine sees at it's peak.
I have to ask...why?
If you've got a throttle body that delivers 100% of the peak air requirements of your engine when the throttle plate is fully open, you have control of the air throughout 100% of the throttle position range. If you go to an oversized TB that delivers 100% of the air that your engine can consume while the throttle plate is only 60% open, you have given up usable throttle-control range for
no advantage.
Guys that are constantly defending the oversized throttle bodies are only talking about wide open performance (WOT). What about the 99% of the time that we cruise around at part throttle?
Throttle modulation becomes more difficult. The gas pedal modulation becomes touchier.
Again, look somewhere else for a restriction, not an oversized throttle body.
An Accufab (for example) 65mm throttle body flows
more than enough for a 347 stroker with 664cfm continously, while the 347 would see 600cfm if it had no heads, cam, or intake on it, which of course is impossible.
Enthusiasts need to quit ignoring the facts.
Read an article from the top throttle body maker themself and let them tell the tale:
http://www.accufabracing.com/article 3.htm
