throttle body spring?
  • Thread starter Thread starter carbed 85 gt
  • Start date Start date Feb 26, 2006
carbed 85 gt
121
Honolulu HI
Feb 26, 2006
  • Feb 26, 2006
Hey guys, I am having a sticky throttle, it will kinda stick at 3000 rpm or so after getting in to it. If I get out of the car and touch the TB it will go back to idle. I pulled the cable and made sure it was routed away from anything that would cause it to bind. I also tapped the gas pedal with this off and it feels smooth and then I opended the TB without the cable on it and it doesnt stick or anything. The TB just feels a bit weak, but does retur to closed positon. Can I get just a spring for mine or ddo i have to get a new TB. BTW it a BBK 70mm.
Matt
KDK1988GT
1,937
Fredericton
Feb 26, 2006
  • Feb 26, 2006
yeh bump for an answer I was wondering the same thing...
Maryland Stang
1,656
30
39
Greenville, NC
Feb 26, 2006
  • Feb 26, 2006
Just put a spring on it like they used to use on carbs.
Euphoric306
905
  • Feb 26, 2006
cabred 85- i've heard of bbk TB's sticking before, most of the time at idle though. try the cheaper way (spring) and if this doesn't solve your problems id look into an accufab 70mm. u dont want your throttle stuck open at 3k rpm when you're supposed to be stopping at a red light
carbed 85 gt
121
Honolulu HI
Feb 27, 2006
  • Feb 27, 2006
Yeah its been a pain wahen it sticks, luckily not at WOT but not going to chance it. I will get a carb throttle return spring kit and adapt it to the TB.
Thanks
Matt
M
Marty Spellman
  • Feb 24, 2018
Hey guys, wondering if I’m having the same type issue? I just bought a Mach 1 and it has a BBK throttle body. It seems like the gas pedal is super hard to press. Once it is moving it’s not bad, just the initial press? I was thinking maybe a spring?
What are your thoughts and where would I buy a spring?
Thanks all!!
Dan02gt
mazing how much gas smell came from that tiny hole
20+ Year Stangneter
Mar 2, 2003
909
415
113
Greenville, NC
Feb 25, 2018
  • Feb 25, 2018
Marty
You definitely brought one back from the dead lol.
I had a BBK TB on my '02 GT back many years ago. It did what it sounds like yours is doing as it would stick closed. What I did to fix it was screw in the throttle stop screw just a tiny bit so that it stopped against the screw instead of the blade binding in the bore.
M
Marty Spellman
  • Feb 25, 2018
Thanks for the response. I’ll give that a try.
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
Engine Coolant leak from throttle body
  • 91GTstroked
  • Oct 9, 2023
4K
Fox 5.0 Mustang Tech Apr 27, 2024
91GTstroked
Throttle body cleaning
  • dz01
  • Apr 29, 2024
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 2, 2024
EmmJay
E
Fox Sticky throttle
  • Dontknowchit
  • Mar 24, 2024
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 30, 2024
Praetorious
P
