  • 2005 - 2009 Specific Tech
Throttle Issue?
  • Thread starter Thread starter 66_stang
  • Start date Start date Sep 16, 2006
66_stang
154
Woodlands TX
Sep 16, 2006
  • Sep 16, 2006
Today, while passing an 18 wheeler in third gear, my baby started bucking pretty wildley. I let off the gas immediatly but everytime i'd give it any gas, it would rock back and forth pretty bad. I talked to my friend with an 05 and he says this has happened to him as well. Thoughts?
JTGrant
775
GA
Sep 16, 2006
  • Sep 16, 2006
that is most likely the fuel pump tsb.
F
FLY2kGT
94
Pinellas Park, FL
Sep 18, 2006
  • Sep 18, 2006
yep, sounds like it to me too.
D
dundy
Toronto, Canada
Sep 18, 2006
  • Sep 18, 2006
I too have had this problem. When I down shift to pass from forth to third and get on the loud pedal fast the car bucks. I was told it was the torque management system I tried it again with the traction control off and it didn't to it.
F
FLY2kGT
94
Pinellas Park, FL
Sep 19, 2006
  • Sep 19, 2006
Dundy...the tcs "kicks in" to prevent wheel spin. Not sure how fast you are going from fourth to third, but I doubt it's the tcs working (unless you have a lot of mods?). One thing about the fuel pump tsb is that the problem usually only occurs after a "long cruise", such as highway driving at the same speed for awhile. Hope this helps.
66_stang
154
Woodlands TX
Sep 19, 2006
  • Sep 19, 2006
^^ sounds just like my problem. I'd be pretty giddy if i could light up the tires in third gear going 95
D
dundy
Toronto, Canada
Sep 25, 2006
  • Sep 25, 2006
From what i have been told is that the torque management system runs in conjunction with the traction control,and monitor the throttle blade angle if any of the values are out, the engine will start to shut down cyl. until the value are correct now it all happens in milliseconds. thanks to drive by wire. Had it happen today uneven road rear suspension unloaded and lose of power. But if my condition continues i too will look into the fuel pump.
and yes wheel spin at 95 would be priceless!!!!
iskwezm
4,159
20
79
Rowland Heights,California
Sep 25, 2006
  • Sep 25, 2006
mine does the same when down shifting and nailing it. Its not the TCS kicking it, its the fuel pupm getting bubbles around it, but im too lazy to take it in.
D
dundy
Toronto, Canada
Sep 25, 2006
  • Sep 25, 2006
now that makes sense, someone said there is a tsb for the fuel pump. has anyone had it done and what does ford do to correct it. found the post by marine one that is the same problem i'm having.
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
3rd person help with a Chevy issue
  • LILCBRA
  • Feb 13, 2025
  • Other Auto Tech
Other Auto Tech Apr 20, 2025
LILCBRA
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
J
Dies on cold start unless throttle is applied and bogs on initial acceleration
  • jake13
  • Jun 26, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2024
Mindseye007
