Really guys..........
Here you go Soljer88, this will 'reset' your throttle position(as it is controlled via the computer).
copy and paste from ResQman over at
Hidden/cool features on 2005-2009 Mustangs... - Page 22 - MustangForums.com (read over that tricks/tips post, its got some great info in it)
Recalibrating your Throttle
Recalibrating the throttle by turning the key in the on position and pressing down to the floor ( total 3 seconds ) then release for 3 seconds.
1- Turn the ignition to ON without starting the engine(dashboard lights come on and chime sounds).
2- After the chime stops, smoothly depress the gas pedal to the floor while counting 1001-1002-1003.
3- Release the gas pedal using the same procedure in 2. (total of 6 seconds pushing/releasing)
4- Wait 6 seconds, and turn the ignition to OFF.
5-Start her up and enjoy
**If it is really quiet when you do this, you can actually 'hear' the computer learning/resetting throughout this procedure.....there is a slight 'whine' when you push the gas pedal down/up(it sounds different the faster or slower you go), and 'clicking' sounds during the wait periods
I really hope this helps your throttle lag(dead peddle) problem, it defiantly helped me; good luck man
