  • 1994 - 1995 Specific Tech
throwout bearing question
  • Thread starter Thread starter icemetalstang
  • Start date Start date Apr 29, 2010
icemetalstang
77
  • Apr 29, 2010
Should the throw out bearing touch the clutch diaphram? If is to loose I get the squaeling sound. To tight it can wear it out right?
Triple hook quadrant- set in middle
Adjustable cable new- pinch cable and twist with finger about 1/4 inch
Fire wall adjuster- left plenty of adjustment
New King Cobra clutch set
New pivot ball-
New clutch fork-
Steel bearing retainer-
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Apr 29, 2010
  • Apr 29, 2010
The throwout bearing should not touch the diaphram when the cluch is engaged. You should leave a little gap in there.
Kurt
G
GDTrumbo
199
Nashville, TN
Apr 30, 2010
  • Apr 30, 2010
Adjust the cable so you have 1" to 1.25" of pedal reeplay. I had a little bit of a strange noise and added a touch more freeplay and the sound disappeared.
GT
icemetalstang
77
  • Apr 30, 2010
Thank you. I have been playing with adjustment for the last week. I have added slack but not inch or so. Ill give it a shot.
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
TKX Install in the Coupe
  • AeroCoupe
  • Apr 12, 2025
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 26, 2026
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
H
New kid on the block
  • HydraX
  • Mar 22, 2025
  • The Welcome Wagon
The Welcome Wagon Mar 22, 2025
HydraX
H
