Thumpage...!
  • Thread starter Thread starter Paul Perreca
  • Start date Start date Aug 2, 2005
1 of 2 Next Last
Paul Perreca
1,085
  • Aug 2, 2005
I have read about thumper heads. Now, instead of sending my heads to them and having them send me a set of their famous "thumper" heads, would it be smart for me to just have my local machine shop whom I know well (and is the best around) shave my heads, which will add a little compression I am told, and port and polish them, and use the appropriate valves and springs (performance enhancing) because thats what it seems like thumper is basically doing anyway, and it just seems like the same. I dunno the differnece. Any help, because seriously contemplating thumper, but its alot less convenient.... and either way, I WILL have my heads or those thumpers... cant afford TW's (want them bad but cant) so please take 2 minutes and post your opinions.. ThANKS!
Paul Perreca
QDRHRSE
1,590
Palmdale, CA
Aug 2, 2005
  • Aug 2, 2005
The thing is that Thumper does a lot of E7 heads....it's sort of his specialty. That's the difference between him and your local guy. If you are comfortable with the your local head shop then go to them. Not all heads are the same and a guy who sort of does generic port work might not get the most power out of a particular head that another porter does almost exclusively. Any reputable shop will make you some extra power. If its such a tough decision go by price.
Paul Perreca
1,085
  • Aug 3, 2005
well i think about it, should I spend 100's more for an extra 5-10 horsepower? Just by gtting the thumpers, or should i just spend the 400 it's gonna cost, and maybe even get really good results by my machinest?
Paul Perreca
9
9 Deuce GT
550
Geneva, NY
Aug 3, 2005
  • Aug 3, 2005
Or you could spend "only $400" and get heads that don't flow any better or make any more power than the stockers. I would just get the Thumpers. He knows what he is doing. Does your shop deal in strickly Ford Mustang related parts?
Paul Perreca
1,085
  • Aug 3, 2005
not exactly, but the guy will definately do his homework for me, so he does it to correct specs for better flow than those E7's
PaulPerreca
QDRHRSE
1,590
Palmdale, CA
Aug 3, 2005
  • Aug 3, 2005
You know, for $700 you can get aluminum GT40 Y heads from Hawaiii racing in Simi Valley California.
1mild88lx
49
Northern California
Aug 3, 2005
  • Aug 3, 2005
I found that out "after" I got my Gt40's off Ebay and had them rebuilt!
maverick0716
3,924
Chilliwack, BC, Canada
Aug 3, 2005
  • Aug 3, 2005
If your machinest is only charging you $400 to do all that, then I highly doubt they will be as good of a job as Thumper460 does on his heads.
Paul Perreca
1,085
  • Aug 3, 2005
hes cheap cuz hes my dads friend. Anyway, these GT-40Y heads, whats with the letters after GT-40, what is the difference between GT-40P and Y and turboswirl and **** - and are these 700 dollar heads fully assembled? or are they bare, and the shipping cost - (not really that much probably, couldnt be more than 100) I'll check it out..
Thanks
Paul Perreca
old_blue
1,783
282
124
Aug 3, 2005
#10
  • Aug 3, 2005
  • #10
Dont you have to run a specific header to clear the spark plugs??? or is that a different GT40 head?
maverick0716
3,924
Aug 3, 2005
#11
  • Aug 3, 2005
  • #11
GT-40 (cast iron) GT-40P (cast iron) GT-40Y (aluminum) GT-40X (aluminum)
The regular GT-40 heads came stock on 93-95 SVT Cobra's and some Explorers. The GT-40P's are a slightly better version of the GT-40's and came stock on 5.0L Explorers after 96-97 I believe. The GT-40Y is an aluminum head and flows slightly better than the GT-40P iron heads.....but you save 50 lbs. off the front end. The GT-40X heads actually flow fairly well (on the intake side anyway) They're about the same as the old Edelbrock Performer heads.
z9_87
332
Urbana, IL
Aug 3, 2005
#12
  • Aug 3, 2005
  • #12
that's the P
maverick0716
3,924
Aug 3, 2005
#13
  • Aug 3, 2005
  • #13
That would be the GT-40P heads.....some guys get by using different aftermarket headers instead of the special FMS headers that are recommended.
old_blue
1,783
282
124
Aug 3, 2005
#14
  • Aug 3, 2005
  • #14
nice , thanks, do the gt-40Y's flow just as good as thumpers??? .... I am leaning toward thumpers right now. I like the aspect of looking stock when you arent.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Aug 3, 2005
#15
  • Aug 3, 2005
  • #15
I ran thumpers for two years. If your going to get aftermarket alumimum heads, get either AFR or TFS's. Thumper heads, besides gaskets and new head bolts, that is all your going to have to buy. Thumper's served me well and I am kind of regreting selling them. I have TFS's now, but don't have a motor to put them on. My car on a worn out motor, almost full weight GT, on 40 series back tires ran 1/8th = 8.4 at 85mph with a 1.8 60ft launching off idle. I had a B cam on 1.7's, Edelbrock performer intake, 70mm tb and 76maf, and full exaust.
vikingpower
656
CWU Ellensburg, WA
Aug 3, 2005
#16
  • Aug 3, 2005
  • #16
Dude, check out Power Heads before you buy Thumpers, the Powerheads are CNC machined and are probly the best E7 head out there. I dont know how good Thumpers are, but Powerheads are worth about 40 RWHP with the stock cam/rockers and a ported H.O. intake. You can check out them out in a project car on MM&FF's site. Dont get hand-ported stuff when you can get premium CNC work! Think of them as an iron version of AFR 165's
http://www.powerheads.com/
I was gonna buy a set of them but went with TW's intead, just saved a little more money... ok more than a little, but when I pulled them out of the box it was well worth it!
maverick0716
3,924
Aug 4, 2005
#17
  • Aug 4, 2005
  • #17
Thumpers as far as flow numbers are concerned would be about in the middle of the GT40Y and GT40X.
D
Dohc32vMarkVIII
58
#18
  • Aug 4, 2005
  • #18
From what I have read, Thumper's heads are pretty badass and flow pretty damn good for a budget stock E7 head, and I know I will be going with his heads when I do my rebuild this winter in the quest for 300rwp! If you are going to be going more radical and wanting more power down the road, you might want to have a set that flows more something like the TW or AFRs
E
emagdnim
391
15
28
Aug 4, 2005
#19
  • Aug 4, 2005
  • #19
1/8th = 8.4 at 85mph , whats the estimate of a 1/4 mile time with that ?
HISSIN50
34
129
Aug 4, 2005
#20
  • Aug 4, 2005
  • #20
Where is Mike? I have not seen him post in a while.
1 of 2 Next Last
D
After Market fuel rails with Stock fuel lines
  • dropteeth
  • May 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 2, 2026
2000xp8
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Tuesday at 10:14 PM
DangStitches
D
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
A
Help ID - Turbo GT, SVO differences
  • aldoelmalo
  • Jun 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 2, 2026
aldoelmalo
A
Autolite 3925 discontinued?
  • 387lx
  • Jan 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 30, 2026
Mustang5L5
