My wing was a little loose and noticed that a screw was missing from the left side. when I tried to put in a similar sized screw it would not tighten up to the trunk lid. I tried to get a bigger diameter screw but they do not make one bigger than a #14. The only way they do is use a lag bolt which I do not like.
What would you do? I though of putting inserts like the ones you use for sheetrock and then using the screw into that. Or, I could fill the screw holes on the wing with fiberglass and re-drill pilot holes and put new screws in.
Or, what about using epoxy to set in some studs on the wing and using a nut and washer?
Any other suggestions? Thanks much!!
