Timing Advance vs Octane Rating
CdnNavybob
105
I'll soon be installing a timing adjuster and I'm trying to determine how much I can advance my timing with the 89 octane fuel that's available to me.
I read about some guys with alot of timing advance, but they also run 90+ octane fuel, which I can't get in this part of Canada.
How much timing advance does everybody run wit what octane.
Also, does a/f ratio have an effect on how much advance you can run? As a side, what's a safe a/f ratio for a mildly modified GT?
Thanks
A higher octane fuel helps in prevention of Detonation. Start your timing at around 15. You may hear detonation, keep lowering the timing adjuster until it stops. Average is around 13.
A TA is a waste of time with 89 octane most likely. Stock timing (as already stated) is at 10. With 89 octane, I doubt you can advance it much at all. Try it. Add octane booster is you want. Advance the timing as much as you can until you get pinging.
