motley said:
do you wait until it gets tacky, or until it is completely dry?
Yeah mine was completely dry...and I guess when I tightened it down it squished against the silicone (because silicone does have a form of elasticity to it...it allowed that)...but installing it after it gets tacky would be just fine to...but mine just happened to work when the gasket was dry...
About installing the lower intake:
Here is what I did and seems to be very successful and was showed this by a buddy of mine that builds race cars...
I put a couple dabs under the 1250 gasket and position the gasket over the ports as perfect as possible and then allow those dabs under the gasket to dry...so it will not move as I lower the intake on...
I put a nice thick bead of high temp silicone on the block ends and let it sit for about 10 minutes to "film" over and then set the lower intake on...you can use long studs installed into your heads to help you lower the intake down and then remove the studs after it is seated...
I slightly torqued the intake down after the "filming" (you can stick your finger to it and it won't come off on your finger) and laying it down just to get a little "squish" on the silicone and let it sit overnight...
The next day I did the final torqueing procedure with the torque numbers (somepeople go by feel) and that was that...absolutely no leaks of any kind...
On mine I had to trim a little bit of the coolant passages on the gasket because it was protruding into the passageway...
This was all referring to my 1250 intake gasket on my AFR's...but it is the same with the stock gasket...
Good Luck with your leak...try to pinpoint it if you can...
