Im taking a 302 out of a 90 lsc and im putting it in my 83 and switching to carb'ed. The lsc motor does not have a provision for the manual fuel pump though, so am I going to need to get an external fuel pump and regulator? Anything else small like this I need to watch out for? Will the stock water temp sensor and oil pressure sensor work? Can I use the duraspark II with the motor as well? Just replace the distributor? I have a distributor for a 351w will it work in the switch? Also what would be the best way for hooking up an electric fan to my setup. Should I put in a switch or set it on a 'run' wire?
