  • 1994 - 1995 Specific Tech
timing cover ???
  • Thread starter Thread starter RIO5.0
  • Start date Start date May 11, 2009
RIO5.0
6,892
N.H.
May 11, 2009
  • May 11, 2009
So Im getting my stuff rounded for the assy on my 331... got a new FRPP waterpump and figure I'd dry run it on the timing cover since just pulled the cover to replace the seal...low and behold she dont fit as the impeller hits????
Seems I have a Fox timing cover...
I read something recently on Explorer covers being the same?? Any info would be great...or better yet if someone has one to sell, 95 or Ex..
Im leaving my motor intact when I pull it instead of stripping it down.
Thanks.....
ProKiller
3,064
15
78
PA
May 12, 2009
  • May 12, 2009
can't you return the pump and get a fox one?
D
Danman765432
471
Nutley, NJ
May 12, 2009
  • May 12, 2009
You can use an explorer timing cover...I bought mine off ebay and it worked fine. If I remember correctly there is one extra bolt hole that winds up getting blocked off my the gasket.
RIO5.0
6,892
N.H.
May 12, 2009
  • May 12, 2009
Thanks guys... I thought the Fox pump is a different rotation than ours ? I would also think I might have alignment issues with pulley's??
SN95StangMan
1,292
Lynwood, CA
May 12, 2009
  • May 12, 2009
yeah, you would have to change to the fox accessory setup. just get yourself the right timing cover.
RIO5.0
6,892
N.H.
May 12, 2009
  • May 12, 2009
Thanks for putting that to bed... I was pretty sure we couldn't interchange..
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
Engine Timing cover installation
  • Sparky714
  • Feb 4, 2024
3K
Fox 5.0 Mustang Tech Feb 6, 2024
Sparky714
Engine Are dowel pins needed to align a front timing cover?
  • evintho
  • Feb 23, 2024
6K
Fox 5.0 Mustang Tech Mar 16, 2024
GOvert
G
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
