timing gear/balancer ??
  • Thread starter Thread starter 87fiveO
  • Start date Start date Oct 26, 2006
87fiveO
1,217
Stanford, CA
Oct 26, 2006
  • Oct 26, 2006
Howdy,
I just rebuilt my 5.0 in my 86 F150. I used comp cams timing gears #2138. When I went to put the accessories on I noticed the harmonic balancer was out too far.
Removing the balancer bolt, it is obvious the balancer is not flush with the front of the crankshaft. It appears that the crank timing sprocket is keeping the balancer from going on any further. It's about 0.2" shy.
So my questions are:
1) isn't the inside of the balancer supposed to be flush with the crankshaft?
2) Is the comp cams 2138 timing gear set too thick? Which one should I use. I think I already threw out the old set so I can't measure and compare thicknesses.
3) Is it likely something else is wrong?
Seems like this should be a common problem with this comp cams part, they say #2138 it should work on 5.0's after march 1984.
Thanks in advance, I'm stuck...
Derek
brin0357
169
  • Oct 26, 2006
Do all your pulleys line up?
87fiveO
1,217
Stanford, CA
Oct 26, 2006
  • Oct 26, 2006
Hello,
no, that's how I noticed the problem. Looks like the balancer needs to go in ~ 0.2"
Thanks,
EMW150
2,020
Roaring Spring,PA
Oct 27, 2006
  • Oct 27, 2006
Is that the origional balancer from the '86? I'm pretty sure the earlier balancers were shorter on the V-belt type setups. If you buy a Motorsport balancer they're shorter and then you have to add a spacer for a serp belt setup.
87fiveO
1,217
Stanford, CA
Oct 27, 2006
  • Oct 27, 2006
Hello,
I think it's the correct balancer, I bought a new one since the rubber on the old one was pretty cracked. But I tried putting the old one back on and had the same problem.
The balancer measures 2.125" measuring how far on the crank I think it should go to be flush. Does anyone know this measurement on the Motorsport balancer?
Thanks,
Derek
EMW150
2,020
Roaring Spring,PA
Oct 27, 2006
  • Oct 27, 2006
87fiveO said:
Hello,
If the old one is the same, it must be the crank sprocket on the timing set.
87fiveO
1,217
Stanford, CA
Oct 27, 2006
  • Oct 27, 2006
that's what I'm afraid of... I'm going to call Comp and see what they have to say.
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Timing chain, guides and tensioner installation (Possible orientation in Intake Stroke)
  • StallionMax
  • Sep 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 24, 2025
StallionMax
Wanting to replace my BOSS 351C Engine Harmonic Balancer - Questions about 'Balance?'
  • 69machmike
  • Oct 31, 2024
1965 - 1973 Classic Mustangs -General/Talk- Nov 5, 2024
Realmongo
Engine TDC @ 30 degrees?
  • DadLife0724
  • May 3, 2024
Fox 5.0 Mustang Tech Aug 22, 2025
DadLife0724
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
