Hook up the timing light's battery leads, clip the pickup on #1 spark plug. Paint the mark on the harmonic balancer you want to use, 10 degrees, 12 degrees, 14 degrees, what ever your choice is. Just make sure you paint the correct mark and that it is visible. I paint TDC red, 10 degrees blue, and 14 degrees white. With a 94 and the tendency they have to ping, you may not be able to use 14 degrees even with 93 octane.
Start the engine, let it idle, remove the SPOUT jumper. On 94 and later models the SPOUT is in the wiring harness near the TFI. The location is different from the 86-93 model cars. Put the SPOUT in your pocket, don't leave it laying around: it is too easy to lose. Aim the timing light at the pointer on the RH side of the engine. Loosen the 1/2" bolt that secures the distributor. I use a 1/2" universal socket & 12" extension with a rachet. Slowly turn the distributor until the paint mark & timing pointer line up. Tighten down the bolt and plug the SPOUT back in. That's all there is to it.
