Ok. I just finished timing the cams on my 2v head swap. Got the dots on the gears matched up w/ the darker links on the chains. The crank gear dot was at 6 o clock. I used a pretty reputable source to be sure I was in the proper places w/ the two cam gears.
I released the tensioner pins, and spun the engine around by hand to be sure there were no interference issues. ( did not sense any interference) Spun it around about 4 times. Noticed that the passenger side chain (especially) would slacken at one point in the revolution but would go tight within about 15=20 degrees of additional rotation.
In addition to that, the dark links have moved exactly 7 teeth from the dots on all gears on both cams.
When you bring the motor around to what should be TDC, the dots are where they're supposed to be but the marked links are not.
WTF?
WTF?
