Timing problem
  • Thread starter Thread starter 89GtConvert5spd
  • Start date Start date Apr 11, 2006
89GtConvert5spd
58
  • Apr 11, 2006
Alright the stang is runnin a little rough for a while now, idles bad, starts and 1000 and drops and back up and drops and evcentually kills, figured it might be the timing, so i have it timed to 25 advance, started to run and idle good, but then i put that little clip back into that haness by the distributor that i was told ur supposed to take out before u time it, and so whenever i put it back in it starts idleing crappy again, am i doing somethin wrong here??
thanks,
-Brandon
Z
ZephyrMotorspor
88
Tampa, Fl
Apr 11, 2006
  • Apr 11, 2006
Put it on a timing light and put it at about 14-16 advanced, i don't see how your not detonating at 25 lol
89GtConvert5spd
58
  • Apr 11, 2006
yea i tried it at 15 too..and whenever i put that little clip back in it idles crappy
Z
ZephyrMotorspor
88
Tampa, Fl
Apr 11, 2006
  • Apr 11, 2006
elaborate on "crappy", up and down?, generally inconcistent? what?
89GtConvert5spd
58
  • Apr 11, 2006
well without the clip it idles great runs way smoother, even runs smoother at higher rpms down the road, but when i put that clip in it idles rough, rpms bounce from 1000-500 uo and down for a while before it kills and it makes kind of a viberation under load at high rpm...can i just run without it in?? or will somethin bad happen?
J
jeremey thomas
142
scottsboro alabama
Apr 11, 2006
  • Apr 11, 2006
question.......are you putting the spout connecter in while it is running or not running?this does make a difference.
1.pull spout
2.adjust timing
3.turn car off and reconnect spout
i did it wrong the first time i ever done this,it did the same thing.but it could also be a bad idle air control valve or throttle position sensor
89GtConvert5spd
58
  • Apr 11, 2006
what does that little clip by the distributor even do exactly??? and could i get away with not having it in at all?? and yea thats exactly how i did it...and still had the idle prob...
J
jeremey thomas
142
scottsboro alabama
Apr 11, 2006
  • Apr 11, 2006
it locks timing in one spot.this sounds like it would be fine to leave it out, but with electronic fuel injection,when air fuel mixture is changing because of throttle response the computer compensates by either retarding or advancing the timing in small increments to smooth everything out.so if you left it out you would run lean and detonate at one moment and run rich and smoke,flood or detonate the next.
J
jeremey thomas
142
scottsboro alabama
Apr 11, 2006
  • Apr 11, 2006
misquote. it locks it in one spot while out.this is how you can adjust.when its in, if you try to adjust the timing will be all over the place.when your timing light is on timing marks youll see it jump all over.
Skoobie
Damn...Tyler65's hot!
May 25, 2003
655
Vancouver, WA
Apr 11, 2006
#10
  • Apr 11, 2006
  • #10
1.pull spout
2.adjust timing
I dont think you need to turn off the car before you reconnect the spout...although i could be wrong...
89GtConvert5spd
58
#11
  • Apr 11, 2006
  • #11
hmm sounds like its kinda somethin i need...and i kinda messed up and made a new problem...i took it out and test drove it down the road, forgetting i left it somewhere in the engine bay...and now its gone...lol any way i can get a new one...
yes i realize my stupidity... lol
J
jeremey thomas
142
scottsboro alabama
Apr 11, 2006
#12
  • Apr 11, 2006
  • #12
yea you kinda have to have it.ive never run one for a long distance without one,but i have run one short distance and it ran smooth, but was very sluggish
89GtConvert5spd
58
#13
  • Apr 11, 2006
  • #13
ok so where do i get one....cuz i screwed up and lost it...
89GtConvert5spd
58
#14
  • Apr 11, 2006
  • #14
could i jsut take like some wire or somethin and connect the 2 connections?? lol anything, anyone???
Skoobie
May 25, 2003
655
Vancouver, WA
Apr 11, 2006
#15
  • Apr 11, 2006
  • #15
Your local wrecking yard...
89GtConvert5spd
58
#16
  • Apr 11, 2006
  • #16
i suppose and 5.0 will have one huh...
seijirou
2,417
DFW
Apr 11, 2006
#17
  • Apr 11, 2006
  • #17
It's just a jumper, so yes you can take a wire and stuff it down in there and have the same effect.
kinda ghetto, but it works.
89GtConvert5spd
58
#18
  • Apr 11, 2006
  • #18
lol sounds like a good fix untill i get to the junk yard
89GtConvert5spd
58
#19
  • Apr 11, 2006
  • #19
thanks guys...makes sense now
Black1987Stang
1,422
Jersey Shore
Apr 12, 2006
#20
  • Apr 12, 2006
  • #20
yea basically it just disables the computer from the advancing or retarding the timing...and just set it from 10-14 with the spout out and no need to worry about what it says when u put it in, the computer does that, i always put mine in while its running though, seems fine to me...what could happen bad if i keep doing it?
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
