Timing Problems
I put 351 Dooe Heads and a lunati cam on my 89 mustang. I am having timing issues. My timing is at 20 degrees and when I try to back it off the #3 header starts to glow. I've double checked the timing marks on the timing chain and made sure that the motor was at top dead center when I installed the distribitor. The cam has .500 IN .510 EX and 284. 292 with a 112 lobe. I have heard that certain cams require more timing.
ok you say the timing is set at 20 degrees. Is that 20 degrees BTDC? Or after? I don't mean to ask silly question but if it is after tdc then you are actually on the wrong side and have retarded your timing. I did this with my bro inlaws 67 dart with a 440 big block in it. Mind you we didn't have any timing marks so we were shooting in the dark.
my 351w is set at 18 degrees initial timing. and it works sweet. total timing with mechanical advance is 38 degrees. Total timing is your intial plus your mechanical advance. Mechanical advance is usalyy all in around the 2500rpm or so mark depending on the strength of the springs holding the mechanical advance wieghts.
You only have one header tube (#3) glowing? Is it possible your firing order is off? Is it possible your new cam is ground for a different firing order than your old cam?
It just seems really strange to me that only one of your header tubes is glowing...???
I'd also be lookin for an issue that's related to just the glowing cylinder's header. Otherwise, all the cylinders' headers should start glowing. :D
If you have an IR thermometer (some DMM's have them these days, or they are pretty cheap in the aftermarket), it might be cool to see what the temp delta is between #3 and an adjacent cylinder's header.
Good luck.
Cylinder balance test:
Warm the car's engine up to normal operating temperature. Use a
jumper wire or paper clip to put the computer into test mode. Start
the engine and let it go through the normal diagnostic tests, then
quickly press the throttle to the floor. The engine RPM should exceed
2500 RPM's for a brief second. The engine RPM's will increase to about
1450-1600 RPM and hold steady. The engine will shut off power to each
injector, one at a time. When it has sequenced through all 8 injectors,
it will flash 9 for everything OK, or the number of the failing cylinder
such as 2 for cylinder #2. Quickly pressing the throttle again up to
2500 RPM’s will cause the test to re-run with smaller qualifying figures.
Do it a third time, and if the same cylinder shows up, the cylinder is
weak and isn’t putting out power like it should. See the Chilton’s Shop
manual for the complete test procedure
Here's the link to dump the computer codes with only a jumper wire
or paper clip and the check engine light, or test light or voltmeter.
I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.dalidesign.com/hbook/eectest.html for more descriptive help
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
For those who are intimidated by all the wires & connections,
see http://www.actron.com/product_detail.php?pid=16153 for what a
typical hand scanner looks like. Normal retail price is about $30 or so
at Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx –
It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
Do a compression test on all the cylinders.
Take special note of any cylinder that shows up as weak in the cylinder
balance test. Low compression on one of these cylinders rules out the
injectors as being the most likely cause of the problem. Look at cylinders
that fail the cylinder balance test but have good compression. These
cylinders either have a bad injector, bad spark plug or spark plug wire.
Move the wire and then the spark plug to another cylinder and run the
cylinder balance test again. If it follows the moved wire or spark plug,
you have found the problem. If the same cylinder fails the test again,
the injector is bad. If different cylinders fail the cylinder balance test,
you have ignition problems or wiring problems in the 10 pin black &
white electrical connectors located by the EGR.
How to do a compression test:
Only use a compression tester with a screw in adapter for the spark
plug hole. The other type leaks too much to get an accurate reading.
Your local auto parts store may have a compression tester to rent.
If you do mechanic work on your own car on a regular basis, it would
be a good tool to add to your collection.
With the engine warmed up, remove all spark plugs and prop the
throttle wide open, crank the engine until it the gage reading stops
increasing. On a cold engine, it will be hard to tell what's good &
what's not. Some of the recent posts have numbers ranging from
140-170 psi. If the compression is low, squirt some oil in the cylinder
and do it again – if it comes up, the rings are worn. There should be
no more than 10% difference between cylinders. Use a blow down
leak test (puts compressed air inside cylinders) on cylinders that
have more than 10% difference.
how long have you ran the engine after one tube started to glow? Thats what happened with my bro inlaws car one tube started but if we let it sit there and idle then they all started glowing. Now about your heads being decked 3 times. Perhaps you have messed up the quench area of the heads? it isn't firing properly or at least as it was designed to?
When the motor was started for the first time after the head cam install it heated all of the banks. We played around with the timing and the fuel pressure,plug gaps. This helped, It started to heat only the #3 header, I removed the 19lb inj and installed a set of 24lb inj. The 24s did not help. Every one that I talked to told me that it was a timing problem. I played with the timing and came up to 20 degrease. The #3 stop glowing at idle, started back turning red at around 3000rpm. I've swapt computers with a freind no change,Swapt inj harness, nothing seems to help................. NO CLUE ON WHAT TO DO..............
I'm not a huge efi guy but are you running a Mass Air Flow set up? If so when you swap out injectors i believe you need to have the MASS sensor tuned for the new injectors. If when you bump the fuel pressure up the glowing went away then it does kinda sound like a lean condition. Have you tried running the codes to see what the computer is telling you? Another option would be to get a wide band O2 sensor. This way you can check to see what your air fuel mixture really is.
Evidently I did not make it clear that you have a potential injector/injector wiring problem. One cylinder with a red stack means one cylinder is running lean.
