I just set the timing on the stang @ 10 degrees BTDC. However, it ran a lot smoother at a higher advancment....much higher. It looked like it was at 15-20 degrees!!!!
What gives? Shouldn't the motor be pining like mad by then? I have low compression (I am assuming around 8.4:1 tp 9:1), but that shouldn't make that much of a difference...should it? The engine is a 1978 302.
-Shaun
What gives? Shouldn't the motor be pining like mad by then? I have low compression (I am assuming around 8.4:1 tp 9:1), but that shouldn't make that much of a difference...should it? The engine is a 1978 302.-Shaun
