timing questions
andycoupe
18
Orange , Ca
need some help?
What timing do you guys think that i should have the car when i drive it with out the Nitrous ? ?
Under the hood I have 306 with a GT 40 heads , GT 40 lower and upper intake, E303 ford racing cam, 24 pounds injectors, Full exhaust with magaflow magapacks mufflers, cold air intake , MSD AL box , 100 shot of Nitrous, Tremec 3550 with a short shifter, 4:10 gears with a full locker , and some other small things too.
Most folks turn it up until it pings and then back it down a degree or two, which tends to be about 14°. That's about the only way to know if you're truly optimizing your advance.
What kind of compression are you running? That makes a difference too.
i disagree wit this method. the engine will start to pre-detonate way before we cna hear it. i tried this method once then checked it with a light and it was 19*. you can rent a timing light from autozone and it doesnt cost nothing.
i say just do it right the first time and dont try to guess at it.
You have to mess with it a bit to find out what it likes N/A. Then pull out 2-4* per every 100 hp worth of squeeze you will use. (IE--using a hundred shot? pull out 2-4*)
set it at 14* with a light then do as stated above.
