Timing with Aluminum heads
billetunderwear
I've posted way more than my fair share of pointle
May 14, 2002
1,148
Rohnert Park, Ca
A friend of mine is running the TFS/Summit combo on a stock shortblock. Roughly how much timing should run with 91 octane? I seem to remember that you can advance timing a few more degrees with aluminum heads over irons because of their heat dissipating qualities.
Thanks!
I run 36 degrees total timing (comes in full at 2400rpm) with the TFS race heat heads, close to 11:1 compression and a very aggressive cam profile. I can also get away with running 87 octane fuel if I have to, but the motor gets hotter, and I imagine it's detonating to some small degree that I can't hear.
Depending on your setup, you may or may not get away with more timing, it's difficult to know such things without testing the motor and monitoring its vitals. I would definately start conservative and see how it performs. Better safe than sorry.
