Timing
  • Thread starter Thread starter 85STANG1
  • Start date Start date May 10, 2004
85STANG1
20
Madison, Ohio
May 10, 2004
  • May 10, 2004
My engine builder locked my timing in at 36 degrees. When I asked why he just said that it was better that way. Can anyone tell me why and the pros and cons af locked out timing versus using some sort of advance?
xplo89gt
945
Boston, MA
May 10, 2004
  • May 10, 2004
I'm not exactly sure what you mean, but you should set your base timing and not total timing. The computer controls that. It varys on rpms.
C
Cobra351
131
  • May 10, 2004
I think what he means is the timing is set at 36* inital and the spout is left out. I have heard some others run this way.Dont know if it is helping or hurting performance though.
85STANG1
20
Madison, Ohio
May 11, 2004
  • May 11, 2004
ttt
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 11, 2004
  • May 11, 2004
Not a good plan. The computer is much smarter than your mechanic, or at least the engineering team that designed the computer is smarter.
The computer varies spark advance using air temperature, engine temperature, air density, RPM & engine load as factors. Lock the timing and some apsect of performance will suffer. The car will be hard to start and tend to kick back at the starter when the engine fires.
Locked timing will work on engines that run at a narrow RPM range, like an aircraft engine, water pump, or generator. Car engines run the RPM range up and down a wide range, 650-5400 RPM for a stock engine in good shape. No one fixed spark timing will work good througout all that range.
85STANG1
20
Madison, Ohio
May 11, 2004
  • May 11, 2004
Thanks for the reply. To help clarify things, it is an 85 without a computer. Should I go to a programmable ignition box?
HISSIN50
34
129
May 11, 2004
  • May 11, 2004
i am in agreement with Jrichker.
that said, i have heard of folks running it locked-in (in your case, without vacuum advance, i assume)....but those folks often have a retard controller in the cockpit (no, that does not mean a device to control me while i ride shotgun ). that way, they can retard timing for start up, etc. i think Big Bernie runs locked in timing with his S/C'd set up (i could be wrong, but that is my recollection).....
good luck.
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
G
Help with initial Microsquirt ignition setting
  • germain101
  • Nov 13, 2025
  • Digital Self-tuning Forum
Digital Self-tuning Forum Nov 15, 2025
Mustang5L5
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
