Tips on breaking in engine
  • Thread starter Thread starter 66moneypit
  • Start date Start date Apr 21, 2005
66moneypit
536
Northern Va
Apr 21, 2005
  • Apr 21, 2005
Heard a few things but I'd like to ask the experts.... (and it might not clear a thing up)
What's the best way to break an engine in. It's running and I let it idle for a minute or so but haven't driven it yet.
DarkoStoj
929
Detroit
Apr 21, 2005
  • Apr 21, 2005
nuff said
http://www.mototuneusa.com/break_in_secrets.htm
69Rcode_Mach1
1,473
Salt Lake City, Utah
Apr 21, 2005
  • Apr 21, 2005
Exactly what that link says. Make sure to clearance your bearings though. If they are not clearanced properly oil flow will be limited and could fry the engine. Also remember to let the ENGINE WARM UP before you get on it. I would recommend having some friends or something go in front of you and having a cop watch you will be going pretty fast doing that break in procedure. It is proven to be the best and is how I plan to do it when I am done at the end of may or so.
66moneypit
536
Northern Va
Apr 22, 2005
  • Apr 22, 2005
That definitely goes against the grain of what I have been reading. I would think it might be different with older engines...but I am by no means an expert.
6Stang7
1,470
Livermore, CA
Apr 22, 2005
  • Apr 22, 2005
nope, do difference. just do the 20 high idle for you cam if you have a tappet cam. other then that, run the piss out of the motor. my boss did that with the race 347 we built and it has yet to have a problem. he also used synthetic from the get go, so that dispells another myth in my mind.
Hack
1,945
Minneapolis
Apr 22, 2005
  • Apr 22, 2005
Yeah that's the one thing that bugs me about that article, nothing about cam break in.
Unless you have a roller cam, you need the 20 minute cam break-in, right?
Route666
1,652
Brisbane, Australia
Apr 22, 2005
  • Apr 22, 2005
Yep hack that's right. You can think about engine break in by thinking about well built performance motors, by that I mean ones with gas-porting and lower-tension rings. The rings by their own tension don't push hard enough to break themselves in, and the point of gas-porting is to make the combustion pressure more effective at sealing the chamber while dragging less on strokes without pressure. So the only way a motor like that is going to break in is with some load on it. The principles on cylinder sealing are still the same in stock setups, but ring tension is greater and so it is less important to run so much load through it as the rings contribute more to the break in force required.
Oil choice for after break in period.
  • Sask84gt
  • Feb 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 14, 2026
Praetorious
P
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
E
Chasing Vacuum leak 99 GT
  • EBNS_2005
  • May 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 3, 2026
X-cam34
