Tips on tuning Wilwood PV
  • Thread starter Thread starter N8Miller
  • Start date Start date Jun 26, 2004
N8Miller
I need NOS....make it 2 of the big ones
2,661
Kingston, PA, USA
Jun 26, 2004
  • Jun 26, 2004
I just had my 4 wheel disc brakes done. my mechanic didnt have time to set the PV and said that it wasnt that hard. I was just looking for some tips on what to look for (when adjusting) and what are some good steps to go by.
thanks in advance
BlackFox5.0
3,514
Massachusetts
Jun 26, 2004
  • Jun 26, 2004
Start by turning it all the way in, then 4 turns out. Adjust it by 1 turn, and 1/2 turn for fine adjustments.
All the way out = full line pressure.
Drive the car get up to speed, and slam on the brakes, if the rears lock up too soon or before the front, then you have too much pressure going to the rear brakes, turn the knob in to correct this. If they don't lock up at all, you might have too little pressure, turn the knob out. You want to find the point just before where they lock up Locking the rear brakes is bad. If you change to a different brand/style/size tires you might need to readjust.
Lxpony
355
central mass
Jun 26, 2004
  • Jun 26, 2004
actually I think all the way in is max rear line pressure - think of a water spiket on the outside of your house - the PV works directly opposite of that - all the way out the most restriction, all the way in the least.. (there are arrows on it either way just wanted to clarify)
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 26, 2004
  • Jun 26, 2004
See MattGT90's instuctions at http://mjbobbitt.home.comcast.net/mustang/mc.html.
BlackFox5.0
3,514
Massachusetts
Jun 26, 2004
  • Jun 26, 2004
I have mine all the way out for full line pressure, I can still get my brakes to lock up. I need to change the pads...
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 11, 2026
keel
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
Fox Traction control
  • Sparky714
  • Nov 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 20, 2026
Sparky714
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
Front window issues
  • bruno
  • Nov 7, 2026
Fox 5.0 Mustang Tech Nov 17, 2026
AeroCoupe
