tire fitment
  • Thread starter Thread starter vvcci
  • Start date Start date Nov 14, 2010
V
vvcci
  • Nov 14, 2010
If I drop the stock rear sway bar on my '70 and add rear air shocks will Goodyear Polyglas L 60 15's rub? I am using 8" wide Magnum 500's.
frdnut
20
Ontario ,Canada
Nov 14, 2010
  • Nov 14, 2010
It will depend on the backspacing of your rims..Do you know what they are?
2+2GT
3,333
10
79
Southeastern Pennsylvania
Nov 14, 2010
  • Nov 14, 2010
Well, I can assure you air shocks will degrade your handling and possibly destroy your shock crossmember.
68RCodeConv
345
Houston, TX
Nov 15, 2010
  • Nov 15, 2010
Air shocks are bad because they unload the rear springs (can you say wheel hop?) and raise the center of gravity. Longer shackles are bad because they overload the rear half of the spring.
If you have problems with the wheel wells hitting the tires then your tires are too wide or your wheel backspacing is wrong. Air shocks and shackles are just VERY poor bandaids.
V
vvcci
  • Nov 15, 2010
4.5"
V
vvcci
  • Nov 15, 2010
Thanks for the advice. Just trying to get some FAT tires under the car without affecting the ride height...much. Stock on my Boss 302 were F 60's and when I saw they were reproducing the L's I thought maybe......
tx65coupe
Nov 16, 2010
  • Nov 16, 2010
Whatever you do, DO NOT use air shocks. They can damage the car. Also they handle and ride poorly.
What is L 60 15 equivilant to in modern sizes?
V
vvcci
  • Nov 16, 2010
Okay, no air shocks. The closests I can come to in metric is a P275 60R 15 with a tread width of 8.7". The old L60 Polyglas GT has a tread width 9" and a section width of about 11.4 on an 8" rim. I would never consider shackels, but how about spacer blocks on the axel perches?....that is if there is any chance of the tires fitting. I'm not looking to raise the car in the back any more than necessary.
tx65coupe
Nov 16, 2010
  • Nov 16, 2010
Putting blocks on the axle perches will lower the car. Its the opposite of a truck.
If you need to raise the back of the car, I would use the shackles from Mustangs Unlimited etc that have one additional hole. They are short enough to stay hidden behind the valance. That will raise the car about 1/2 or 5/8 of an inch.
It may just be the the springs on the car are old and have sagged some. If thats the case, new springs might be what you need.
I have seen 69-70 Mustangs with 255 60 15 on the rear, but I don't know about 275s.
dodgestang
1,360
Cecil County, MD
Nov 16, 2010
#10
  • Nov 16, 2010
  • #10
You know if you plus size the rim you put 275 right on with an issue right?
275 40 17 are an easy bolt on.
201
#11
  • Nov 22, 2010
  • #11
I run a 275/40/17 on my falcon. and a hoosier slick on my mustang with a 11.5" section, 10" tread and 26" tall.
Tire size question 1986 gt hatchback
  • B0udreaux
  • Jan 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 17, 2026
B0udreaux
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
G
In expensive ceramic coating
  • gray owl
  • Jul 12, 2026
  • Mustang Sound & Shine All
Mustang Sound & Shine All Aug 18, 2026
NotaVegetarian
N
G
Fox Tire Size for 16" Pony Wheels on 1984 LX Convertible
  • gw7
  • Jun 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2026
Qtrhrse23
