Tire Pressure in BFG Drag Radials?
well with my 15s i leave mine at 30psi's and i actually have to much traction so you gotta kinda play with it. i think the smaller the side wall the less pressure you want and it also matters on how much HP your running
You have it backwards.. Generally you use lower pressure with the taller sidewall to take advantage of the "wrinkle". With 18's you want to run them a little higher. I would start around 22 and drop from there based on your traction. I usually run my 315 17's at about 17-18 and they hook well. Ultimately your power level, suspension, track conditions and launch technique will all be factors. As others have said its all about trial and error. What works for you one day may not another. Start high because it's easier to let air out than inflate. ;)
