Tire Question on 17's
68rustang said:
why so narrow?
Not my first choice, I have someone who has some rims that they will give me for $250 - they are actually 7.5 rims.. I'd love to have some nice rims for $250 - If they are only .5" off of 8" then would it be really that bad?
Also can get 18x8 for $350 from same guy. Might go with these instead, only I've never seen any stangs with 18's on them. From dodgestang's chart it shows I should run 265/35 and 245/40
now you've seen 18s
I'm not recommending this, I'm with the other guys - my taste says they'd look bad on anything smaller than a '69, but here is Hal Baer's sweet '69 sportsroof with 18x10. It looks MEAN. :cool: It's your car, if you dig this look, see if they would fit on the dodgestang chart.
I too would question that 275 on a 8" rim. Got any pics of that??
68rustang said:
How much are the sidewalls pulled in?
A 275 tire is a 10.8" tread width, that is rediculous on an 8" wheel.
My nitto DR measures just hair over 10". i wouldnt say rediculous, probably not the most ideal for roadcourse work but fine by all means for street duty. Take a look around stangnet, or anywhere for that matter...275DR's on a stock 17x8 wheel is very a common practice
i dont believe its effecting the tires performance as ive cut 1.7s with that setup, and havnt found any abnormal wear either
SitDown said:
a 255 on the 7 will be fine...ive been daily driving 275s on a 8" for years
I have 275's on a 8" now and had 245's on a 7" and you could barely see the sidewall bulge.Heres mine.I dont see a problem :shrug:
url]
The reccomended wheel widths for a 275 is 7.5 to 9.5 inches and I'm seeing 7.0 to 9.0 inches for 255's according to summit racing.
Of course this will change if you have rubber bands for tires...like I see a 40 series 255 on a 17 inch whose range is 8.5 to 10
