Tire Rubbing Sound ... '87 5.0 Convertible
StanCotreau
hi folks,
I've a '87 5.0 convertible. I finished the body and top, car runs well but one thing is driving me crazy.
when I turn the wheel all the way (like to parallel park) I hear a sound that resembles a tire rubbing. But I cannot see any signs of this ........ has anyone had this issue??
I should note that there is also a vibration in the front end, not sure if they are related
any help is much appreciated
Stan
New struts shouldn't cause an issue like that. I would look around the front end to see if you see anything shinny like it has been rubbing. It is possible that a clip or two from the inner fender wells has come loose and one is slightly out of place to cause this. Honestly stock wheels with a stock size tire at stock ride height should never have a rubbing problem. Sounds like you will find it to be an easy fix once you get under there to see what's going on! Best Wishes
-Nick
